Go Back   ZR-1 Net Registry Forums > General > Past Events & Event Pictures
Old 05-18-2009   #11
Default Re: BG 2009 Videos Drag Strip
Originally Posted by Pete View Post
Just got back.
11.1 @ 127.76
The video is my second pass clutch was gone it didn't wanna go in gear.
The 60 ft was good 1.60 the first one was better 1.59
Man what a gear change can do (4.10's)
Them Buick boys sure know how to prep the track, holly cow.
My clutch is fried,had enough just to get me home.
Was a great time weather was great 80f and very humid.
The Buick boys told us if we wanted we could've raced on Friday also.
Anyway more later i'm tired and i have to relax my shifting arm for next week racing,of course after a fresh clutch.
Bob's 427 ran good he was trying/testing a new cluth i'll let him explain.
You also have to remember we just finished that car a few days before BG.
Pete
Pete
Great seeing you again and your car is a finely tuned machine!@!!
The buick guys were so gracious and the dates are set next year to hang / drag with them again.
Looking forward to another great year next year (20th anniversary)
Old 05-18-2009   #12
QB93Z
QB93Z's Avatar
I have thought about this a lot also. Here are my thoughts, and I am asking for feedback.
Imagine a ZR-1 with gears for wheels and sitting on a toothed track. From a standing start, to get a rapid acceleration, you would have to slip the clutch until the car speed is fast enough to get the engine rpm at usable rpm. Then you want to get to peak torque rpm as quickly as possible. With a higher rear end gear ratio (ie 4.10:1 versus 3.45:1), the engine will get to peak torque sooner (sooner meaning a lower car speed).
In other words, during the time it takes to get from a standing start to engine at max torque rpm with the wheels gripping and the clutch fully engaged, you are not making maximum acceleration.
In a poor launch, when the clutch pedal is released, the car bogs down because the engine rpm is low enough that engine torque can't sustain the rapid initial acceleration. With a higher rear end gear ratio, the engine rpm is higher when the bog occurs, so it should not be as severe.
Am I thinking right? (I am in no way an expert about drag racing and I want to learn.)
Old 05-18-2009   #13
Jagdpanzer
Jagdpanzer's Avatar
Originally Posted by Aurora40 View Post
Cool, nice work on the PB Jim! If I'm not mistaken, that's a PB for you too Phil? Or no?
Don't take it the wrong way, but seeing Phil's and Keith's cars spin like crazy from the line helps me feel better about sticking with the stock 3.45's. I'm sure with some more grip and if I had more skill, the car would be faster with 4.10's, but I think I'd just be blowing the tires away all the time.
Bob, yes this was my best so far.
You my recall first time out last fall at Capital Raceway I broke a spindle on the very first pass and had to be trailered home. (thanks again David and Jeff for bailing me out)
I believe the 4.10 gears are a good match for the quarter mile with the way I have my car set up. RPMs appeared to be right around 6500 going though the traps in 4th gear on my best run. Traction was tricky business though. It was great right after they put the sticky stuff down however, it seemed to drop off quite a bit after 25-30 of those storming Buicks worked it over. The run of my car in video 5115 was taken when the track was at its poorest and the tires still at 35 psi so I had a lot of wheel spin coming out even though launching at 1500 rpm. On my best run later in the day the track had about 15 runs on it since last prep and I had the tires down to 20 psi. Came out at around 2000 rpm and this time the car hooked very well but bogged bad. My target at BG was to make the twelve's and not break anything. With this accomplished I called it a day.
Old 05-18-2009   #14
Aurora40
Aurora40's Avatar
Engine bog should be the same as it is with tires on the car. In both cases, the traction exceeds the engine's ability to deliver force.
With 4.10's you should be able to drive through bogging better, because the shorter gearing means it takes less acceleration/time to get back into the powerband.
With unlimited traction, 4.10's should certainly be better as you can't blow the tires/cogs away, and the gears get you into the powerband sooner. Once in the powerband, I believe both cars would accelerate more or less the same. The 4.10's should help the short game primarily, and help you make the most of more traction. You'd just rev it up and dump the clutch, and keep an eye out for where your driveline parts land.
For me the problem is not having that extra traction, and not having the skill to dance the fine line without blowing away what I've got.
Last year I don't think I ever ran in the 13's unless I missed a shift. Yet my best time wasn't much better than you or Phil ran this year. It's just I could generally be in that ballpark vs the wild variation when you smoke the tires with 4.10's.
That's my take. But I'm no expert either.
Bob Saveland
Former owner of #2517
Old 05-18-2009   #15
"Imagine a ZR-1 with gears for wheels and sitting on a toothed track."
Jim,
Pete wants to know "Where you get these tracks?"
Bob,
Interesting because Lgaff and I have very similar '92 setups including the same headers (Watsons 1 7/8"). I'm running the Magnaflow with resonator and Xpipe, while he has Xpipe, no res, and Borlas. He has 4.10's and I have the 3.45s behind a Fidanza FW.
Lee has always gotten better 60' times and 1/8 mph. His et has been
.2-.3better. The last time we raced heads up our traps speeds were within .01 of each other.
Old 05-18-2009   #16
Aurora40
Aurora40's Avatar
Bob,
I don't doubt the 4.10's result in better short times. I'm guessing he's a good driver. I'm sure if I were a good driver, I might find the 4.10's more appealing. But it's about what the car will run with me at the wheel that matters.
Bob Saveland
Old 05-18-2009   #17
QB93Z
QB93Z's Avatar
I did learn one thing about 4.10:1 gears on this BG trip. There were 5 ZR-1's running together for part of the trip. We all filled up and drove together and then filled up again. My '93 has 4.10:1 rear end. The other cars have stock rear end. The average to fill them up was just over 9 gallons. I put in about 10 gallons. Glenn may have the actual numbers and the miles we covered, but I used more gas, as you would expect.
Old 05-19-2009   #18
Locobob
I traded in my 4.10's for 3.33's and am pleased with the results. Didn't care much for the traction issues in first gear plus I can now complete the quarter mile in three gears instead of four. Maybe with some race rubber the 4.10's would have been more to my liking but I prefer a run what you brung approach - off the highway straight onto the track.
Robert
