Old 05-17-2009   #11
Default Re: Shift Light Install
Originally Posted by Pete View Post
If your installing the shift light in the vent.
You can pick up hot and ground from the center console the extra wires the factory has left for just this reason.
They are by the hatch release botton (center console).
Pete
Pete, the extra wires I don't think started until 91.
Old 05-17-2009   #12
Pete
Pete,
I'm using those connections for my WB. If you're taking the rpm signal at the
diag connector I can pull 12v switched and ground from there and just run it as a harness to the interior.
Old 05-17-2009   #13
bobbyhi
bobbyhi's Avatar
Mine's done and works great. Thanks guys for the help
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 05-18-2009   #14
Pete
Pete's Avatar
Pete,
Dom, my WB has cigarette lighter cord for powering the WB.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 05-18-2009   #15
Pete
Pete,
I believe the LM-2 was built to work that way. The ZT-2 isn't. In fact, the instructions specifically state not to use the cigarette lighter for power.
When I first got mine I did use the lighter and it worked fine. I also had TPS output being logged by the ZT-2. It worked fine and then the car started running erratically with TPS signal being interfered with by WB. Once I hooked it up to switched power and used ECM ground the problem went away.
