Old 05-13-2009   #11
secondchance
Default Re: Fuel injector question
http://www.zr1specialist.com/HAT%20W...eplacement.pdf
Interesting. This article talks about retro fitting 93-95 injectors to 90-92 motor.
On page 2, it says lower body of 93-95 injectors are 0.027" smaller (I guess they mean in diameter) and says will require larger injector O-ring.
Interesting article by ZR1 Specialist.
It sounds as though flow rate is not a major issue. Nonetheless, I will see if I can get exact flow rate for early LT5.
Old 05-13-2009   #12
yeah but since i am using 93-95 IH that should not be an issue either
Old 05-13-2009   #13
secondchance
True, bottom of injector go into IH.
Old 05-13-2009   #14
secondchance
Are you running 21 lbs? Any mods to the motor?
Loading up on fuel.. too much fuel, but then the one bank would show lean and then it would adjust to go rich but then see too much fuel on the other bank from the leaker. but that just does not make sense
Once again, I think when one injector is rich system tries to compensate and keeps going back and forth.
I imagine, when one is clogged, it may do the same (lean, detect richen, too much, back off, lean, and so on).
I would pull the plenum carefully, replace the leaker then, for now, patch where gasket breaks (if it does) with a dab of O2 sensor safe, high temp sealant, see if its a fix and if so, replace with the new gasket.
Good luck and keep me posted. Don't give up! I chased my problem for years finally to be resolved recently.
Old 05-13-2009   #15
Should be 21lb.. Will check with Jon
mods:
headers, Exhaust
93-95 IH and plenum
car is a 90
Old 05-13-2009   #16
secondchance
See edited version above.
Old 05-13-2009   #17
yeah gaskets are holding okay.. only done 4 plenum pulls with them.. I bypassed coolant from the plenum so the job is not that bad.. but still
Yeah going to check a few things, get them ready and do another pull to swap the Multecs for the FIC.. Talking to another Owner, sounds like it is possible that one leaker would cause those issues too..
Old 05-13-2009   #18
Toyvet1
Jeff I had one secondary leaking a small stream on passenger side a dropplets leaker on drivers side and you saw how the car ran when it got towed home. But coolant was also leaking , so it might be time to try the fic injectors
Toyvet1 is offline   Reply With Quote
Old 05-13-2009   #19
Okay will do..
Maybe this weekend
Old 05-15-2009   #20
Drove car today with Multecs.. runs fine
Swapped to the FIC ones tonight
hoping weather is nice in the next day or so to try
