Old 05-20-2009   #11
USAFPILOT
USAFPILOT's Avatar
Default Re: Injector machining done.
how is it coming rick?
Old 05-20-2009   #12
rhipsher
rhipsher's Avatar
Did you look at the top pics...those are CNCd just like yours.
I sure did. Gee! Could you possibly be a machinist also! If so we are probably the last of the breed. If you havn't noticed, there is a shortage of qualified people. Its scary. Half of them can't even read.
Old 05-21-2009   #13
Wish I were a machinist....but no.....bought it that way.
It was pulled out of a pile......was done years ago I assume
Old 05-21-2009   #14
rhipsher
rhipsher's Avatar
It looks like who ever did it kinda missed the mark.
Old 05-21-2009   #15
That's the head side of the injector housing and the primary port that looks off center. The primary is only 32mm stock compared to the secondary @ 36.6mm. The runner isn't directly over the port, making it look like the counterbore is off. I think it's OK.
Old 05-21-2009   #16
rhipsher
rhipsher's Avatar
I havent done anything since I got them off the machine because I don't have a ball gauge to check them with. I've been meaning to make one on the cnc lathe but we are so busy there's no way to squeeze it in. I don't want to start grinding till I have a gage. The porting won't take long but after that I've got to send everything out to powder coat. God knows how long that will take to get back. The car is probably going to be down a couple of months. But I'm in no big hurry. After mine are done and everything works right I'll do your 94 Z and then Rob wants me to do his 93 Z. I 'm the sacrificial Guinea pig. We will talk about price after mine are done. Then I'll have a better idea of whats fair for all the work including removal and reinstall or not.
Old 05-21-2009   #17
Fooseball=35M used that instead of a ball guage
Old 05-21-2009   #18
rhipsher
rhipsher's Avatar
I was thinking maybe a golf ball if its the right size.
Old 05-21-2009   #19
flyin ryan
flyin ryan's Avatar
Forget about that ball deal , everybody seems ssooo hung up on that. Just use an inside telescoping snap gauge or even some inside dividers, would/will be fine.
Old 05-21-2009   #20
golf ball is in the 40 range.....ping pong is 38 and that seems too large....I have 391 rwhp and used the 35MM
