Old 04-18-2012   #11
batchman
Default Re: Change Oil Light Reset Procedure
Did you hit the range button and hold which is the final button for the procedure on your 91?
Pounded on it like the deranged monkey that I am. Tells me all about the range but without a flashing CHANGE OIL that's all I get.
Yikes,
- Jeff
[/I]
Old 04-18-2012   #12
Yikes,
- Jeff
Hmm well post #6 IS the correct procedure. I dont know what is going on there.
Old 04-19-2012   #13
mike100
http://www.youtube.com/watch?v=8Addi...layer_embedded
for the earlier cars the 'range' button is the one to push because there is not a gauges button that shows the digital coolant and oil temps. the above video should work.
Old 04-19-2012   #14
batchman
The deranged monkey sometimes wins.
Finally hit the cadence that worked, even 1/2 sec intervals ENG/MET ENG/MET RANGE. That got the flash, then held RANGE 10 sec or so. Phew.
Thanks for the support, some days I just don't get along with GM stuff!
Best,
- Jeff
[/I]
