Old 05-01-2009   #11
secondchance
Default Re: Service Ride Control
Perhaps I am missing it but it does not indicate which position the ignition key should be in while grounding. Should it ne in run position or off position. Does it not matter?
Thanks.
Old 05-01-2009   #12
Jeffvette
Key has to be in the run position.
Old 05-01-2009   #13
secondchance
Thanks.
Old 05-01-2009   #14
secondchance
Alright! That did it.
U started out with 23, 31 and 34. Replaced left front gear, tightened retaining nut, finally reset the code and now all I have is 34.
I am waiting for rear shock grommet and when I have my mechanic replace grommets, I will inspect right rear actuator.
Thank you Jeffvette!
