Old 04-23-2009   #11
Zr1 Destroyer
Zr1 Destroyer's Avatar
Default Re: Non ZR-1 Dyno graph help
Originally Posted by limey View Post
Under boost im @ A/F of 11.3 As per the bottom graph, the top is NA.
Ry, the car is Fuel Injected, the O2 sensors were unplugged though as i was using a FAST wide band meter to read A/F, would that cause the ECU to miss read fuel adjustments and such and cause this problem?
I would think so since the fuel map feeds directly from the wide band o2's.
Is the car set up with a one or a two bar map from the factory and did you switch up to a three bar?
In my Syclone the factory shipped them with a two bar set up wich read fuel mapping up to 14.7psi, but after that boost level the ecm would go static and dump fuel and pull timing.....almost like a false knock situation.
With my PLX wide band now in my truck I had to ad a three bar map to read and let the ecm ad or subtract timing/fuel past the original 14.7psi two bar factory speed density set up.
Are you on speed density or running a maf?
Zr1 Destroyer is offline   Reply With Quote
