Old 04-13-2009   #11
Default Re: Fidanza install complete.
Originally Posted by rhipsher View Post
I'm using the stock clutch. And the part# for the sprung hub disk is CTF-381039 at Summit Racing. You have two choices there for disks either the Center Force that I went with or the McLoed. Summit was out of stock on both so it took me over a month to get it. I also went with longer bolts for the flywheel to crank and for clutch to flywheel. All grade 8 preasure bolts not just any bolts.
Thanks, I really appreciate the info. I was holding back because I have heard about all the rattle at idle. It's bad enough that people think I have a problem with smoke from the exhaust.....all I need is some rattling and it will seem like a POS.
Old 04-13-2009   #12
jonszr1
jonszr1's Avatar
no worries ,just have your prom changed so your idle is about 850 and you cant hardly hear it .the good is she revs like crazy .one of the best mods you can do .jmho
Old 04-13-2009   #13
rhipsher
rhipsher's Avatar
I wouldn't have yanked the transmission for the sole purpose of putting the flywheel in and I wouldn't suggest doing it for that. But if its time for you to replace your clutch and you have to remove your trany anyway then that is the time to do it. Kill two birds with one stone. You notice the faster RPM gain from 1st through 3rd. After that its not any different than it was before. I'm sure after I p/p the plenum/inj housings there will be a much more noticable difference in power in all RPM's and gears than with the lighter flywheel. And with Jeal headers and 4:10 gears even more. Going with the Fidanza is about the equivalent of rerouting you tempeture sensor to the front of your car. But it's one of those nice little incremental improvements that add up. And you really only hear the gear noise when your car is well warmed up and your in nuetral. It all depends on how anal you are about things weather it bothers you or not. These cars already sound like a diesel truck. Go run your car up to 180mph for 5 minutes and then slow down and pull up to a stop light. That sucker will be rattling regardless of that duel mass flywheel. It won't be loud, but you can hear it. Then in a few minutes the car will settle down and be quiet again. I'm only speaking for myself and my expieriences with my ZR-1. Your experiances with "your" ZR-1 may be different.
Old 04-13-2009   #14
...Going with the Fidanza is about the equivalent of rerouting you tempeture sensor to the front of your car. But it's one of those nice little incremental improvements that add up.
I must disagree with you there.
From Haibeck website:
"The stock flywheel weighs 37 pounds. The Fidanza aluminum flywheel weighs 13 pounds. Thus the dynamic weight reduction is 24 pounds. The Dynojet (tm) power output can be expected to increase by about 13. +13 wheel hp divided by a .85 correction factor (15% drive line loss) equals +15 crankshaft hp."
Old 04-14-2009   #15
rhipsher
rhipsher's Avatar
I knew it wouldn't take long for somebody to pop up and disagree with me. Yes thats true but it is also true that rerouting the temp sensor will keep you from loosing 10 HP from heat soak. So was I that far off. I mean I'm no mathmatician but I'm sorry there's not enough of a difference between 10 and 15hp to be that much of a disagreement worth mentioning.
Old 04-14-2009   #16
I can understand the 15hp for the Fidanza. 10hp from
"heat soak" of the MAT sensor?
Old 04-14-2009   #17
rhipsher
rhipsher's Avatar
Well if you don't believe me then here's the link to Mark Haibeks site on the temp sensor. http://www.zr1specialist.com/HAT%20W...r%20sensor.htm
Old 04-14-2009   #18
Thanks for sharing the details and your thoughts. I appreciate it and I'm going to do it when I need to change my clutch. I'm looking forward to getting the 4:10s in and then I'm sure I'll need a new clutch soon after.
Old 04-14-2009   #19
I could see the heat soak affecting the hp if you're on a dyno, but driving around I think its a moot point. Moving the sensor isn't increasing the hp, you're just not giving up hp under certain circumstances.
Old 04-14-2009   #20
rhipsher
rhipsher's Avatar
Niether is adding a light wieght flywheel! It would be like going on a diet and loosing 27 lbs. or taking your spare tire off. Loosing wieght doesn't add HP. It's just that much less wieght for your car to lug around which is naturally going to make it quicker. That's all. But I'm pretty sure we've both beat this thread to death by now. So I'm gonna go cash in my chips now.
