Old 03-10-2009   #11
Jeffvette
Default Re: Emissions retest another failure
Just to add some more info.
New plugs
New coils
New plug wires
Cats are new
Theoretically, this car should have no issues passing emissions. A couple of things in talking to Darryl.
AZ still uses the IM240 testing, which Oregon had and recently got rid of. Having a stock ZR-1 pass on them was getting tougher as the car was never designed to pass that kind of test, and they have also been lowering the passing limits here.
Second, if you have a jack rabbit operating the car on the dyno, it will fail.
Darryl is going to try the stock PROM and see where we wind up and go from there.
Old 03-10-2009   #12
GC,
I doubt it's the DRM calibration. Tuners don't typically touch the Spark and Fuel maps in the area that involves part throttle cruise. I'll bet it's happening on decel.
Old 03-10-2009   #13
I really dont know at this point, Im trying to do the right thing with new cats and even a new o2 sensor. At this point im trying to determine a work around. Daryll
Old 03-10-2009   #14
Originally Posted by tomtom72 View Post
You do have the A.I.R. system connected, right? Not sure if it makes a difference.
No I dont I was told the A.I.R. tubes was only there to preheat the cats upon startup does anybody know different for sure? Jeff Flint states thats the case, are there any other opinions?
I dont remember seeing a smog pump or an air pump on our cars beyond the electric air pump and the air dirverter valve on the drivers side right?
Old 03-10-2009   #15
jonszr1
jonszr1's Avatar
jeff is right they are only for startup and shouldnt effect the test if the car is allready warm
Old 03-10-2009   #16
Well heres my course of action for tomorrow... Put the stock chip back in. Drive the snot out of it for about ten miles at 3000rpm before the test to get the cats nice and hot. Pull over and put in a gallon of denatured alcohol to about 1/3 -1/4 tank of gas, keep it at 2000 rpm while its is the test lane and then test it! Sound about right? GC
Old 03-10-2009   #17
Also turn the A/C on during the above and while being tested.
Good Luck
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 03-10-2009   #18
Ahhh to strain the car even further ok Frank thanks for that idea I will. And turn it off before entering the booth. I will try to take a video of this run through the booth. Jeffvette is intriqued I think he just like to see punishing compliance in action. A few guys on the Grand National forum say they do this all the time to stick it to the man that the car is sputtering, surging and complaining so much that it freaks out the compliance nazis when they pass. I guess RONK was onto something here. Thanks for the help folks as always.
BTW
I just enjoy running the snot out of it too, especially with the Jeals as it barks like big dog now. I cant imagine what your sounds like Frank with that big motor. lol
Old 03-10-2009   #19
PhillipsLT5
PhillipsLT5's Avatar
Collector Ins in AZ= no test req
or
After failing x times and x $ in receipts you can get a waiver
You must be close to that
or contact Marc
Old 03-10-2009   #20
1990 415
the alcohol to use is methyl alcohol. when i bought my first ZR-1 from Frank Urbanati it had a Jeal 368 with no cats. i got that car to pass emissions with no cats on methyl alcohol. you have to basically get all the gasoline out of the tank and then put in a gallon of methyl alcohol for the emission test. once you pass the test fill her up with premium asap. the methyl alcohol is clean but the LT5 doesn't like it for too long. i was elated when i got the 368 to pass without any cats. good luck.
1990 415 is offline   Reply With Quote
