03-07-2009 | #11 |
Re: Closed Deck
this is a 368 4" bore. Steel sleeve.
stock 350 today. Last edited by Polo-1; 03-10-2009 at 08:21 PM. Reason: pictures |
03-07-2009 | #12 |
Re: Closed Deck
Great looking work!
What rod, piston and ring combo did you go with? |
03-10-2009 | #13 |
Re: Closed Deck
It looks like you made god use of the extra space around the cylinders...i know nothing about building an engine...but is the 441 using separate cylinder liners now or is it all one piece, I can tell it is a different color and that some of the original block was bored out. I guess it is also a stroker too, so will it turn similar peak RPM to a stock engine...more? Less? 415's seem to be somewhat common, but this is the only 441 I have heard of so far, maybe others are out there. I think I read about a 427 LT5 as well.
03-10-2009 | #14 |
Re: Closed Deck
i beleive that frank also has a 441 that mark haibeck built for him
03-10-2009 | #15 | |
Re: Closed Deck
I swear...If they have that "all Corvette" run at US41 next fall, it would be fun to see the Zs pin some ears back. (Did a pretty good job of it last year but there was only 3 of us there!) Is it spring yet??? P. |
03-10-2009 | #16 |
Re: Closed Deck
That closed deck looks killer Al Nice work !
03-10-2009 | #17 |
Re: Closed Deck
Al,
I'm impressed! That is drop dead gorgous... I find it interesting that like in the stock engine, siamising all the cylinders isn't causing heat related failures of the rings and cylinder walls. Of course there is no real higher mile track record of these up sized engines. Still, considering this type of work has been for a while now, it appears not to be a problem. H
03-10-2009 | #18 | |
Re: Closed Deck
That Crank is made by Bryant just in case you want to order one. any stroke. Spring is right around the corner friend.We're going to have some fun this year with all boys. AL. |
03-10-2009 | #19 |
Re: Closed Deck
Thunder at Stillwater II would be a great place to show them off!!
Come on Down!
03-10-2009 | #20 |
Re: Closed Deck
