10-30-2009 | #11 |
Re: Can I get a lift?
Yes...if you look a bit and wait for specials... Direct Lift makes an excellent 4 post lift which is certified under the newer more stringent processes>>
http://www.bestbuyautoequipment.com/Articles.asp?ID=133 Take a look at these two distributors (and they compete with each other): http://www.gregsmithequipment.com/Di...pro-park8s.htm http://www.bestbuyautoequipment.com/...tary-s/290.htm I purchased the Direct Lift Pro 8 and am VERY pleased with it>> http://www.bestbuyautoequipment.com/...20standard.htm And here it is installed>> Now for the price range you are indicating....you will not get the option light weight aluminum ramps (lift comes with steel ramps and they weigh 48 lbs vs 18 for the aluminum ones and the sliding hydraulic jack which allows you to lift the car off the wheels>>>
Michael :cheers: [I][SIZE="2"]1990 RED on RED #566[/SIZE][/I] [I][SIZE="2"]WAZOO MEMBER[/I][/SIZE] |
10-30-2009 | #12 |
you will need to move the garage door rails up I bet
I am also thinking it will be a tight fit you just storing one? I know of a place to just store it for the winter.. good rates, my 89 sat in one the first year I had my Z
10-30-2009 | #13 |
I will not need to raise the door, clears the post and with the car in backwards is not an issue. I look as storage cost as giving away $, would rather put the same $ into a lift. Would have to be very very cheap to go the storage route.
10-30-2009 | #14 |
it was $350 or less TOTAL from now until April
10-30-2009 | #15 |
[/quote] How well does the rolling jack work?? Thanks
Jon R. Member #490 1992 ZR-1 Arctic White/Red 2008 Z51 Silver 6 spd (Daily driver) |
10-30-2009 | #16 |
Ill measure the garage in the morning and let you know how much clearance.
10-30-2009 | #17 |
Ever heard of these guys, they are just down the road:
http://www.rhilifts.com/products/par...stallation.php
10-31-2009 | #18 |
I know a 4 post is great for storage but what about working on the car are they not just a pain in the ***??
I can get a jack and jackstands under that car on the 4 post I know that so I don't need the 1K jack that sits under the car nice but unessesary in my eyes. I want a lift to do work on my cars but im hesitant to get a 2 post at this time due to the installation and Im not at a perminate residence. So in that case a 4 post is the all around better choice but I still want to know your guys opinion on working on the car on this lift and I mean suspension, engine, tranny, exhuast work you name it! jp
10-31-2009 | #19 |
Not to hi-jack this thread but you guys/gals seem to be using lifts for storage......I need something to just drive up on and get off the ground about two feet to change oil and work underneath. Kind of like Phrogs has in mind. What do you guys/gals use for that?
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-31-2009 at 02:18 PM. |
10-31-2009 | #20 | |
