#11 |
![]() Join Date: May 2007
Thanks for the discussion.
I have read the NetRegistry HowTo section and I agree with what you have posted. It is reassuring to hear that someone else has had the "momentary" fault that turns on the light but then goes away so there is no code number stored when you try to read the code. I thought I was using the Tech 1 wrong. I will try swapping wheels around to see If I can figure out which wheel is the problem. QUESTION: Will the wheels from my 1996CE have the correct sensors for the 1993? Am I right in believing that if a wheel sensor had been permanently damaged during tire remove/install the LPTWS light would come on and there would be a code number set? Has anyone had that happen? |
#12 | ||
Make sure you clear everything out code wise before you put on the other set of wheels.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 02-25-2009 at 12:50 PM. |
#13 | |
The units emit a radio frequency to the receiver. As long as the receiver gets that code, it does not care where that sensor is sitting. The reason they are color coded is they have a certain code tied to them. That code then signifies that the band now has an issue. So now that you know the band that is causing the issue you can go to the corresponding wheel, as long as they are installed in the correct location. |
#14 |
Thanks for the clarification Jeff. It all makes sense to me now.
I guess the most direct way to find the "lazy" sensor will be to put the wheels on the 1996 one at a time and see which one causes similar symptoms. |
#15 |
Any updates?
#16 |
Are the wheel sensors the same for all years?
If not, will earlier year sensors work on later year cars and will later year sensors with ealier year cars? |
#17 |
No they are different MY 89-92 used the Black bodied transmitters and MY 93-96 used the White bodied transmitters. Both had different frequencies so you cant mix and match. The bodies of the units are a different shape and the counterweight is different on the strap band as well.
However, has anybody actually really tried to see if a set of 4 newer transmitters will work on a older car or vice versa? Not that I have read about anyway in any forum. No matter what set of four transmitters are used they do transmit a frequency. I wonder if the older cars will read the newer car frequency and not error out? Good question, would be great if somebody had both and earlier and later car and could swap wheels for the good of the cause. My guess is probably not as the LTPWS module are probably set to scan for only a certain frequency.
#18 |
No update. I have been busy with our business. I won't get a chance to swap wheels until next week. I will let you know.
Jim |
