#11 | |
Just installed an Alternator for a Z brother in our "VA plenum Pull" @ Michael R's home..... Glen paid $130 for an alternator from Kurt White (wasn't OEM, not identical to original, but worked). Installation wasn't too bad. Just a few bolts and had to move some hoses. I'll get you the "brand" that we used. I think you can purchase it for much less @ any auto store. ![]() David |
#12 |
![]() Join Date: Mar 2007
When the headlights and blinkers are on the volt meter is swinging back and forth bigtime.
#13 | |
![]() Join Date: Jul 2007
the OEM voltmeter?? what about headlights only? I am thinking there is no issue, I am pretty sure my 90 does the same thing, but I cannot run ot and check, it is still an hour away
#14 |
Well after after discussing with Jeff sounds like the Alt is fine, must just be a difference between the 90s and 92s.
#15 |
Well my 91 doesnt do that either Lee. Maybe some other MY 90 owners can chime in here as well.
#16 |
I went and got my 90 today.. so I called Lee while in the car.. mine is just as he describes.. I think it is a non-issue
#17 |
pull the battery, remove tray, then clean and remove paint on the frame. The 90 model has a TSB for this. I did this on my 94 too. It helped with the dash volt meter bounce.
http://zr1netregistry.com/Old_Proj/old_proj7.htm |
