Old 01-05-2009   #11
jonszr1
jonszr1's Avatar
Default Re: Shift Lights, Set At What Max RPM??
no they arent done . corey did say i had one of thehighest hp cars he had done . in fact the car has 157k on it now . corey would be proably be the best person to share about my car. my callaway 475 super natural made 373 wrhp stk. and ran 12.78 @113.88 stk. after stainless works headers and cat install it has run a best of 12.48 @116.47. the black car also has 4.10s the callaway has 3,92s . i am going to change out the headers and exhaust from the black car and put on the callaway and see what the difference is for fun . the jeal headers seem to have longer and more equal length pipes . other than that i dont know what to say other than that is the results that we got .hope this helps
Old 01-05-2009   #12
jonszr1
jonszr1's Avatar
the spin tec guys did an awsome job on the exhaust . they used 23/4 in pipe instead of 3 in saying unless i made a bunch more power 3 in would take alot of low end out of the car their exhaust made 22 more hp than the flowmaster system .
Old 01-05-2009   #13
Robm3
Robin, what are the ratios in the transmission & differential?
Jeff,
It's a G50/OO, 1st, 2nd and 3rd are lengthened 4th and 5th as standard, this was done before I brought the car though.
Not sure what the ratios are, have a sheet somewhere but suspect it's in a box in the loft with a load of invoices my wife can never see!!
I do find the 5th gear a little short and thinking of getting 4th and 5th changed upwards to suit though.
Standard is:G50/00 3.5 2.059 1.409 1.074 0.861
Funny enough I was just looking at a shift light that worked on a combination of speedo and gear selection, Could be adjusted for different shift times depending on gear, sounds good but a little complicated for me to fit.
Robm3 is offline   Reply With Quote
Old 01-05-2009   #14
Jeffvette
Robin, it really depends upon your gearing where you need to shift. See if you can get the ratios and we can go from there.
Old 01-05-2009   #15
tpepmeie
Originally Posted by xlr8nflorida View Post
I believe you have the dyno sheets but those numbers just don't make sense to me unless you just have a beastly LT-5 from the factory.
Are your heads done?
You should be in the 400-410 range. Maybe you just have a really strong LT-5.
This isn't the first time we've been through this conversation on Brad's car. He even posted up the dyno sheet here once I think. Two things I can remember, 1) Corey's #'s are corrected to STD, I think. and 2) there was an anomoly at the end of the run when the throttle was shut which spiked the indicated RWHP to the 409.9. Going from memory, but I think that was the essence of the discussion.
Back to your regularly scheduled programming.
EDIT: my memory is slightly failing. Here is the thread. Wasn't Brad's car, but I would guess same phenomenon would be seen in his graph. we know it is corrected to STD, not SAE.
http://forums.*************.com/c4-z...on-a-dyno.html
Old 01-05-2009   #16
xlr8nflorida
xlr8nflorida's Avatar
I'm just saying it seems odd, like they are not corrected numbers but what do I know
Old 01-06-2009   #17
1990 quasar blue
They are corrected but, to STD not SAE. STD numbers read a little higher than SAE. I always thought that they sounded high too but, you can't argue with 120 MPH trap speeds.
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
Old 01-06-2009   #18
jonszr1
jonszr1's Avatar
you are right they are corrected to std. but there is no spike at the end . i need someone that can give me a fax number that will post the sheet for me .the car does seem very strong running between 119-120.5 even when the das are 2500+. the spin tec custom exhaust i had done was the icing on the cake .it is loud but when she runs that good who cares
Old 01-07-2009   #19
xlr8nflorida
I guess when i say corrected I mean SAE.
Those are the numbers I use when I talk about RWHP.
Either way, the #'s are respectable.
Old 01-07-2009   #20
jonszr1
jonszr1's Avatar
is there a way to correct them to sae. on the sheet is temp and humidity?????/
