Old 01-03-2009   #11
32valvZ
32valvZ's Avatar
Default Re: Vibration.
My limited thoughts are these ...... You say it was since the last rip to the drags, hmm. The things that are stressed the most would be clutch, transmission, U-joints, axle shafts and their U-joints. I would probably add in the motor mount as well, but from your description, I'm not 100% sold on that.
I would think that maybe the pilot bushing or the input shaft bearings could be the culprit. I say that because its happening on hard acceleration.
It almost sounds like there may be a combination of problems. The hum can be wheel bearing related as mentioned, or still a bad U-joint. U-joints are hard to pin down sometimes because alot of times, they dont make it obvious that theyre bad, unless theyre totally shelled.
Well, thats my .02
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 01-03-2009   #12
rhipsher
rhipsher's Avatar
The new clutch only has about 3000 miles on it. And after I installed it I had the transmission fluid changed and the guy said that my trans fluid is nice and clear and thats a sign that the transmission is in good shape. It shifts so smooth and easy and it grabs great. So I'm not so sure its the trans. But I do buy the wheel bearings point on the humming sound. So my money is on the u-joints failing or the motor mounts or both. Once I have my morning nukie I'll go look for it and let you know what I find.
Old 01-03-2009   #13
Jagdpanzer
Jagdpanzer's Avatar
FWIW had a similar problem a while back and turned out to be a bad tire.
Old 01-03-2009   #14
rhipsher
rhipsher's Avatar
It could be a bad tire. Last saturday when I put the NOS upper A-arm on I took it for a spin and up to 130 it felt so bad that I decided to just back off before I ended up with a drive shaft going up my azz.
Old 01-03-2009   #15
rhipsher
rhipsher's Avatar
Ok here's some video. And when I say the drive shafts look like they have alot of play in them I meant running out alot. Maybe .05 at least. And when I read on the common issues part of the forum that talks about drive shafts and them running out only .002? There's no way in the world mine are. The main drive shaft runs nice and true comming out of the transmission but when it gets to the rear it starts to run out about .05. All the old u-joints are Spicer.
http://s301.photobucket.com/albums/n...LEWABLE001.flv
Old 01-03-2009   #16
Polo-1
pull the driveshaft, pull one cup off.wipe grease off the cross, is it smooth or does it have dents in it from the needles. You dont even have to pull the shaft all the way out of the car, just the diff end. These drive shafts have no angle to them and will "box car" the the u-joint cross, and flatten the needles.
