Old 01-02-2009   #11
Default Re: Original Factory NIB LT5 Thermostat Housing!
Originally Posted by phrogs View Post
This has to be one if the most asked for parts requests that I get.
do these break quite often? or get damaged?
Old 01-02-2009   #12
xlr8nflorida
xlr8nflorida's Avatar
Electrolysis can do them in over time and also if you or your mechanic is not careful, you can break it.
Old 01-02-2009   #13
limey
Agreed,
At least twice a month! When anyone buys a motor from a junk yard, they always leave these bolted to the frame and they get destroyed or lost. Hot rodders too, buying crate motors never come with the motor, they need these as well.
Second most requested part, coolant crossover tubes.
On a side note, i had quoted to make these thermostat housings a couple years ago, cost was less than $500.00 for them if i remember correctly, i'll wait to see what this goes for and decide if i should pursue this project.
limey is offline   Reply With Quote
Old 01-02-2009   #14
Sgreg
Sgreg's Avatar
Originally Posted by limey View Post
Agreed,
Kurt, I think you estimated $650 for the repro not $500. Could be wrong though. Interesting sidebar on the new Bay t-housing. The quick disconnect fitting is not the original design. Has been replaced with the new design so you "all correct folks" may need to find a fitting for judging.
1991 ZR-1, Black, Black, # 541
Sgreg is offline   Reply With Quote
Old 01-02-2009   #15
limey
I just checked my initial post & it was back in 2006:
Price for outer piece, GM part # 14104599 is going to cost $265.14
Price for Inner piece, (This been the part where the over flow pipe attaches
into, as well as houses the Thermostat) GM part # 14104598 is going to cost
$395.26
If you buy the two pieces as a set, the cost with thermostat and seal
included is $624.41
Good memory you have!
Old 01-07-2009   #16
Jagdpanzer
Jagdpanzer's Avatar
Winning bid:US $655.00
Jagdpanzer is online now   Reply With Quote
Old 01-07-2009   #17
Jeffvette
If he had sold it this past summer or a year ago, 1k easily.
Old 01-07-2009   #18
Sgreg
Sgreg's Avatar
A bargain !!
Old 01-07-2009   #19
Too rich for my blood for shelfware. So who got it???
Old 01-07-2009   #20
xlr8nflorida
I put a bid of $745 and crossed my fingers.
