Old 03-08-2009   #11
tpepmeie
Default Re: A few parts for my next engine
Originally Posted by Polo-1 View Post
Hows the build going Todd.
Snail's pace. This market is killing me.
Waiting on the induction system back from the head shop, (still). Next hardware to order will be the pistons, probably from CP, but I need the final chamber volume to figure the dish.
Got a sample of the final valvetrain pieces now, retainers, springs & seats, locks, and bucket followers. The valves are o/s stainless with 7mm undercut stems.
At this point, I might just concede and do the 402 rather than the big bore 427. Either would be more than enough power. I have to decide if the extra cubes are worth cubic dollars!
How's yours?
Todd
Old 03-08-2009   #12
Wow, awesome stuff and thanks for sharing. I am starting to feel like I'm too poor to be on this site. I sure am envious when I see all these builds................
Old 03-08-2009   #13
Polo-1
I really like the 427/441 Al is working on. The price is more at a range I could work with. The liners and block work look good from the pictures he posted.
How's yours?
Hurry and wait. My bearings are at Calico for C-1 coatings. I sent them a set of Kings, GM, and Clevite. One thing after anther
Old 03-09-2009   #14
I agree, man those are some really impressive building materials all you guys are using!
Craig, I thought that I was the "token" poor person....okay it must be that the politically correct ratio is a bit larger! I was thinking that I got in under "The Equal Opportunity ZR-1 Owner Program"!
Old 03-09-2009   #15
'Either would be more than enough power'
Very true Todd.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 03-09-2009   #16
Tyler Townsley
Todd
Figured you would be doing a bit of traction control code for the ecm to keep from burning up the tires at every stoplight. You see the post on the LS 2 coils? Looks like an answer to ignition module failures as I think its the heat that gets them.
Tyler
55 Polo White (Project)
61 Jewel Blue (Sold to buy above)
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 03-10-2009   #17
I'm just lucky to own a ZR-1 and being all I can be already. I am maxed out and don't even know what I would do if my LT5 needed a rebuild. At least I'm not alone. Well, living in Hawaii doesn't help with the high cost of living we have here....how about paying $650,000 for an average home. I got in under the Equal Opportunity ZR-1 Owner Program too; I'm on of the low bid Ebay guys.
Old 07-06-2009   #18
Jagdpanzer
Jagdpanzer's Avatar
Not to butt in...... This is my 402 build.
Moldex 4" with 2.00 rods
I went with Crower Maxi-Lite B-4 with upgraded bolts, 625g but I plan to hit it with N2O
Ron Woods Liners/and studs
Top end with be Mono runner into heads, From Greg VanDeventer
I like that ATI damper, can you tell me more on it.
Hey Polo,
Can you update us on how is the 402 build is coming along?
Old 07-07-2009   #19
Polo-1
Sure
The top end should be done 2-3 weeks
The block is in Spokane now. They need to make tq plate for the block. I think he said it will be 4" T-6.
ARP studs for the bottom end are a no go. I tried to have them made, no luck. I'm to small of a order, I guess. I wanted 5 sets made, no luck.
Ron Woods is working on having them made ( multiples ).
Everything on the LT5 just takes forever to get done. It has not been a cash shortage on my end. I guess if I did all the work myself it would go faster. I don't have Rottler boring and Sunnen honing tools. As porting, I'm only OK at it. I want this little 402 hit 625-640 (motor hp) then the NOS on top.
How yours doing Todd
Old 07-07-2009   #20
tpepmeie
Things are moving now. Block is in Chicago and now waiting pistons. Crank is getting ground down, also waiting pistons for final balancing. Heads are, well, closer. Should have final chamber volume today so that I can finally get the pistons ordered. Cams are waiting flow numbers from the heads. It is all interdependent.... If I don't get these heads back soon. 15 months and counting. Better be worth it.
Funny, I also went down the ARP main stud path. They finally stopped returning my calls.
Todd
