12-27-2008 | #11 |
Re: Ball milling reamer??
Have a 36, 37 and 38mm chrome ball. Want to say I got them from McMaster, Ill double check. Ordered them with a freind years ago.
On the bit you need a way to control where it cuts, dragging ot through wont work. I use a good ol fashioned grinder and an assortment of carbides.
1990 ZR1, 142,000 miles-Black on black 4.09's Haibeck chip, 3"exh, K&N, meth inj. |
12-28-2008 | #12 | |
12-28-2008 | #13 |
I think it needs to be ground out by hand, then if you have the money to spend.... ex honing would be icing on the cake.
12-28-2008 | #14 | |
1. Average velocity; 2. Individual instantaneous velocities; 3. Shape/design (maximize a homogenous velocity profile over the ENTIRE port & at the same time promote efficient flow); 4. Rate of velocity change; & last 5. Airflow; If a person follows these five variables you'll soon find out the most important rules of designing an induction system are: Velocity, Velocity, Shape, Velocity &, finally, Airflow. I try to keep my engine building arm out of this forum, for the most part, but i hate seeing people going down the wrong road, so i apologize for partially stealing this thread. it wasn't intended. i could have jumped in many times in the past but i just let it go...can't educate everybody. i still don't know why some people think they can port out of the blue just by picking up a die-grinder? i call them carbide cowboys. you know what they say...a little bit of knowledge is dangerous...so true. one last thing...i PORT, not polish! i make the intake tract as rough as possible, the ONLY time i will lightly polish is on the exhaust port side & the only reason for that is so the carbon will have a harder time sticking to the port walls & building up over time on a street driven engine. absolutly nothing to do with so called flow. i've said enough
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
12-28-2008 | #15 | |
According to this expert, The worst spots on the LT5 induction tract are the head-to-housing interface, and the too large bowl areas beneath the valves. The head-to-housing area is troublesome in that to make the air follow the awkward turn, the cross-section area of the port has to be slightly larger than optimal. I will say, overall, these heads will still be smaller & faster than current thinking in LT5 port work. Cant wait to get them back! Todd |
12-28-2008 | #16 |
Like i said the porting world is small. funny you should mention Darin though, we talk every few days. all the higher end guys' thinking runs along the same lines. Tom Slawko, Ron's, Carl Foltz, Curtis Boggs etc. sounds like you've got a good guy doing your stuff, which is good to see. seems like there is a bubble around the LT-5 world. that's why i try to stay out of these type discussions on here, i don't want to step on any toes, so to speak. i always tell guys, an engine doesn't know what name is on the valve cover or in this case a cam cover. treat each port to itself & follow proper principles & techniques, things will work out for themselves. don't do something just because so & so did it & you are led to believe it is correct. i never 'assume' anything.
12-28-2008 | #17 |
I found the reference. Here is a very good article by Darin on the subject.
http://www.competitionplus.com/2006_...der_heads.html One of those guys you mentioned is taking my LT5 heads to the next level! A long R&D project, which hopefully is nearing completion. |
12-28-2008 | #18 | |
How long before you will have your new engine running? |
12-28-2008 | #19 |
FR,
Given that our manifolds are dry, how does that change the principles of porting? Or does it? What's your view on direct injection and any modification it suggests for porting? |
12-28-2008 | #20 | |
I did my own intake and got 391 rwhp without even tunng the car yet, I'm not a pro but I am $1200-$2400 richer than if I sent it out. I also did an intake which I sold to Hans(CCMANO) and will be interested how his car does with the port job.....have another intake that I bought and am working on it now. There is a learning curve with it but as with anything to me there is a diminishing return on everything......how much extra time, cash etc to pick up a few more ponies.... I was also able to recreate the smooth finish of the extrude hone with lots of WD40 and 800, 1000, 1200 grit paper but what is it really worth?????? I did it on my intake but would not do it again. LGAFF "carbide cowboy" LT-5 hack 92 ZR1 #234 |
