Old 12-29-2008   #11
Default Re: ZR-1 and Shebly wheels ( Polishing and cleaning)
Originally Posted by Locobob View Post
For sealant my local wheel shop recommends GE Silicon II window and door sealant - available at Home Depot. You won't need the sealant unless you pull apart the wheel barrels, the centers can be removed without doing so. Torque the perimeter bolts to 20-25ftlbs, they don't need thread locker as they have locknuts on them.
Thanks Robert..
Any particular sequence for tightening?
Old 12-29-2008   #12
Locobob
Thanks Robert..
I would alternate sides - like tightening lug nuts
Robert
Old 12-29-2008   #13
Are all three piece wheels like this (Sealant issues?) Im think even Fikse Fm series? GC
Old 12-29-2008   #14
Yeah I was thinking 4 bolts in a '+' pattern and then shift the pattern left then right.. etc until all tight
Old 01-03-2009   #15
Hey Locobob,
I removed one Center tonight.. the nuts do not appear to be lock nuts.. What Loctite would you recommend? They came apart rather easily, so the 20-25 ft lbs make sense
Old 01-03-2009   #16
Locobob
It's possible some of the wheels have different hardware on them, I have a different style bolt between the fronts and the rears. If you don't have the lock nuts I'd use a low strength lock tight - you may want to take them apart again someday.
Robert
