Old 11-17-2008   #11
Default Re: Wiring Harness
Originally Posted by 40zr1 View Post
Well guys, shows you how much I know about this modern machinery. My wiring experience goes back to if you needed it run, you could run a wire from the battery to coil and jam a screwdriver across the starter poles. Crank it and go! Nothing like points and carburetor!
And what I'm looking for is something like that, a basic wiring harness that would have an ignition switch, starter switch and what ever else necessary for basic engine operation. Couldn't I wire the inst gauges, A/C and other stuff on another circuit? I don't know?
But I want to thank all who have responded and please throw out some other ideas if you have any. Thanks
Really not possible. Everything is interrelated, fuel, spark etc. You can't run that motor without the specific LT-5 ECM. If this was a Gen 1 or 2, you can run with some other aftermarket, or you could even go the
carb route, but not possible with LT-5.
Old 11-18-2008   #12
65ZR1
Most aftermarket engine harnesses are what they call a three wire system. You plug in all the connectors to the engine, fans, fuel pumps etc and whats left are three wires. One is always hot, the other is switched on with the ignition and the last is a ground. A/c, instruments, starter are done with another harness like those available from painless wiring. These include a fuse block and everything needed for lights, starter, horn etc.
65ZR1 is offline   Reply With Quote
Old 01-24-2009   #13
Topfuel
Topfuel's Avatar
A FAST XFI can run the engine I building a 90 twin turbo with an automatic for my 69 camaro . If you dont want all the actuators for the second set of ports and such it is actually very easy to do. The fast system can run 16 injectors low or high inpedance. hot roding these engines isnt that hard. Just my .02 worth . Sherbie
Topfuel is offline   Reply With Quote
Old 01-25-2009   #14
Topfuel,
You don't have a CCM to contend with.
