Old 11-13-2008   #11
key_on
Default Re: New lift finally installed
Hmm my garage roof is higher but the garage door hangs down lower. Can I see a pic of the clearance of the garage door?
I'll post a pic of the door tomorrow. I had to have it raised, which required the installation of a jack shaft opener. Not cheap, but a good solution.
key_on is offline   Reply With Quote
Old 11-13-2008   #12
Ahhh haa!! Ok I was wondering about that yes please do
Old 11-13-2008   #13
QB93Z
QB93Z's Avatar
GC, Here are some pictures of my lift. The jack shaft opener is very important to get a good install. I learned a very expensive lesson with my original Genie Screw Drive.
If your door opening is a standard height, you just need to add track extensions to "raise" the door out of the way of a car on the lift.
The door on the right has an extra door panel to allow the overhead door opener to reach it. You can see the extension in the tracks that make the door higher up when it is open.
The black "L" shaped piece is a car killer if you are not careful!!!!! That is what the jack shaft opener eliminates.
And, the Money Shot:
Old 11-13-2008   #14
Jagdpanzer
Jagdpanzer's Avatar
Here is the manufacturer's site for the Liftmaster 3800 jackshaft garage door opener that both Jim and I installed.
http://www.liftmaster.com/consumerweb/pages/productmodeldetail.aspx?modelId=834
I bought it online here
http://www.prodoorsupply.com/Liftmaster_Model_3800_p/b020.htm
Old 11-13-2008   #15
Thanks Guys I will need to check all of this out. Now I understand how this works....
Old 11-13-2008   #16
key_on
I promised a couple of pictures of my reconfigured garage door. It is hard to distinguish the door from the ceiling in the photos. In the raised position, the door is about an inch from the ceiling.
Old 11-13-2008   #17
QB93Z
QB93Z's Avatar
You got your garage door really close to the ceiling. Good Job. Looks nice.
