Old 11-01-2008   #11
Jagdpanzer
Jagdpanzer's Avatar
Default Re: NoVA/MD/DC/WV, one last 1/4 mile run of the season?
Finally got the MT DRs and Hoosiers on Pete's old front skinny A-molds so I'll be ready to do battle with you speedy MD boys, weather permitting of course.
Old 11-01-2008   #12
QB93Z
QB93Z's Avatar
I look forward with great anticipation to watching the Master at work.
Old 11-02-2008   #13
HIZNHRZ
Originally Posted by QB93Z View Post
If it would help to look at your rear suspension on a lift, I am glad to let you put your car up on mine. Give me a call or email if I can help.
Jim, thank you very much for the offer. Depending on how things go, I might take you up on it. It only takes a few minutes to exchange the stock leaf spring bolts for the longer aftermarket bolts. I've manage to change one in between a bunch of "honey do's" today. I will get the other bolt changed out tonight and test drive it.
As long as nothing rubs, it would be great to drive up to your place and do the final adjustment on a lift. With a lift, I could get under the car easily enough to make the adjustments and immediately test drive it. (It seems the lift would eliminate me having to raise the car, set the jack stand, remove the tire, adjust leaf spring bolt, and then reverse the process - probably 3 or so times!)
What are you doing Tuesday besides vote?
Thanks.
Old 11-02-2008   #14
Aurora40
Aurora40's Avatar
You can adjust the nut with the car on the ground. Though perhaps that's not good for the nyloc type nut?
Old 11-02-2008   #15
HIZNHRZ
It is possible but difficult. I think is because the extra inch of rim I have is on the inside. Also, I'm using a plain nut until I get the adjustment correct. Then I plan to put on the nyloc nut.
Old 11-02-2008   #16
QB93Z
QB93Z's Avatar
Thanks.
Tuesday would be fine. I will be around all day and evening. Come on up. I sent an email with my address.
Old 11-02-2008   #17
HIZNHRZ
Thanks Jim, I'll be watching for it. Did you include a phone number? I'll give you a call before hand.
Old 11-03-2008   #18
QB93Z
QB93Z's Avatar
I just sent an eMail to our list of MD and NoVA ZR-1 owners. I hope some other area ZR-1's will join us for a day at the races, either to race or just to come and hang out.
Old 11-08-2008   #19
Aurora40
Aurora40's Avatar
Looks like rain is forecast for next Saturday, which is a good sign that it won't rain then. If they were forecasting a perfect day, I'd be worried!
Old 11-08-2008   #20
Heard from many Z owners...
Frank said he might come too! With or without the Z, come visit Frank.
