Old 10-30-2008   #11
Default Re: Need to choose a new radiator
I was thinking the same thing when I took out the rad on my 90 to clean it. Surprisingly it was in good shape as the original owner kept up with the maintenance on the cooling system and didn't use the car much. I was doing a samco hose kit and my oil cooler hose r&r project and decided it would be a good time to clean the cooling stack also.
Not to make work for you but here is a link that I found to be a very useful alteration/addition if you use your Z alot.
http://www.zr1netregistry.com/ZR1_radiatorscreen.htm
I average about 5K a yr and every week I get to see what junk would have gotten into my cooling stack.
Oh yea, thanks for the mention of Fluidyne....I completely forgot them in my thinking about where I will get my replacement radiator when the time comes.
Old 10-30-2008   #12
Hmm im wondering if its the underside of the crossover tube or more likely the thermostat housing extension that is approx in the center next to the radiator is the culprit or the hose that connects to the TH housing on the underside.Further back in the center its gotta be the waterpump. I would get her up to temperature while on a jack stack and then look underneath.
Old 10-30-2008   #13
Aurora40
Aurora40's Avatar
FWIW, the DeWitts is on sale until 10/31. They also claim you no longer have to trim the fan shroud to use the rad.
Old 11-02-2008   #14
Any updates on the Radiator project?
Old 11-08-2008   #15
1991ZR1
No change yet. I just got back home from the SEMA show so I'm really tired. Also somewhat poorer. Maybe next weekend I'll put the car on jack stands and run it to try to see where the water is coming from.
1991ZR1 is offline   Reply With Quote
Old 11-11-2008   #16
QB93Z
QB93Z's Avatar
The radiators are exactly the same. As stated above the Automatic transmission lines are just not used and a standard radiator can be had as stated for $150 shipped to the door. The new OEM style radiator will work fine.
I bought a "OEM" radiator on eBay that was supposed to work in the ZR-1. It is a Delphi product, Part # RA1138.
The radiator is the 1990-1996 style but all the ones in the system have the auto transmission cooler connections on the right end tank. The idea is that you don't have to hook up the auto trans cooler lines to install the radiator in a manual trans car.
BUT:
The problem is that the auto trans cooler in the right end tank blocks the opening where the radiator outlet hose connects. Here is a picture of the outlet:
The tan colored piece you see in the opening is part of the transmission cooler. There is less that 3/8" clearance between the opening edge and the tan piece.
I decided not to use the Delphi radiator because I think that the flow rate will be compromised by the restriction.
I could not find any of the OEM radiators that were for a ZR-1 (manual trans C4) so I bought a DeWitts radiator. It is a thing of beauty:
As soon as I get my Samco hoses I will be putting it in.
Old 11-11-2008   #17
Jagdpanzer
Jagdpanzer's Avatar
Jim,
Which Z is getting the new radiator?
Old 11-11-2008   #18
QB93Z
QB93Z's Avatar
Jim,
The Red '90. It is leaking from the right end tank. It started leaking after the first time I did a nice hard acceleration.
Hey Phil, are you coming to Mason Dixon Dragway this Saturday?
Old 11-11-2008   #19
Jagdpanzer
Jagdpanzer's Avatar
Jim,
You bet!
Already have the new set of MT DRs on the back plus the skinny A-molds I got from Pete last summer shod with 5.3" wide Hoosier Pro Street radials on the front.
This weekend I pulled the plenum and put a new set of Accel injectors in. While at it also removed the coil plate and starter to titivate (that's sailor talk for make smart or spruce up for you lubbers out there) the valley. Checked out the secondary vacuum system out to make sure it was tight and working properly and changed out the inline fuel filter. Still have to put in a new set of NGK TR55IX Iridium sparklers then this Torch Red ZR-1 from Virginia will be ready to wage 1320 warfare with you boys from MD at Mason Dixon Dragway this Saturday.
This will be my first outing to the strip with the Z so I'm not sure what it'll do, probably low thirteen's or high twelve's at around 110 mph is my guess. Let pray the weather holds. If lot of Zs show up maybe we can declare this event the inaugural North verses South ZR-1 Mason-Dixon Line showdown.
Old 11-12-2008   #20
Jim when you put those Samcos on remember you have to seperate the top off the TH housing to get the lower short hose on then reinstall the top of the TH housing. Wont work any other way.
You are correct you wont find a MT radiator in the inventory anywhere. And... the Delphi is GMs one size fits most solution. So far its been working great for me. Did you have to cut the shroud with the Dewitts?
GC
