Old 10-20-2008   #11
Default Re: Plenum gasket glueing
Originally Posted by UKZR1 View Post
The plenum is ported for a 368 so the gasket needs to be trimmed quite a bit and I cant afford for it to move around at all.
Just an FYI here..... The plenum gaskets I make have 37.5mm port dia., so no need to cut gaskets to fit ported engines. They still retain a narrow port divider and can be used on stock port size as well. They are available in the 0.030" thickness, same as OEM, and ).042" thickness if preferred.
About the 1/4" phenolic spacers; I ran them on my car for awhile and doubt there is any appreciable gain. Makes the alum vac tube on the driver side fit poorly and also means you now need 2 sets of plenum gaskets. Worth the money? I don't think so.
Old 10-20-2008   #12
Chris_32212
thansk for the info on the phenolic spacers. didn't realize that i would also need a second set of gaskets. gasket thickness of .42 if preffered? why would that be preferred? terribly curious. thanks again
Chris
Old 10-20-2008   #13
Originally Posted by Chris_32212 View Post
.....thickness of .42 if preffered? why would that be preferred? terribly curious. thanks again
Chris
From my perspective, the 1/32" (0.031") thickness is just fine. User preference on the 0.042" thicker gasket. I just make them available.
Old 10-21-2008   #14
Chris_32212
i guess my question is, why would someone prefer the thicker gasket?
Chris
Old 10-21-2008   #15
LoTu5
Chris
Sometimes when there has been extensive inlet work to the plenum the heat distorts the mating surfaces with the IH's and the thicker gaskets help with a better seal.
A26B, good to know you have these available.
LoTu5 is offline   Reply With Quote
Old 10-21-2008   #16
Chris_32212
thanks for the info bud!!!
Chris
Old 10-21-2008   #17
UKZR1
UKZR1's Avatar
Thats useful. YHM!
Red/red 90 #1281 (UK)
Marc Haibeck 368
B&B, Brembos
DRM suspension
Known as 'Gixer' on corvettechat.co.uk
www.corvetteclips.co.uk
UKZR1 is offline   Reply With Quote
Old 10-21-2008   #18
Jagdpanzer
Jagdpanzer's Avatar
Chris
Like other things in life some guys just like it with more in the middle.
Old 10-22-2008   #19
Chris_32212
i guess size really does matter.
Chris
Old 10-22-2008   #20
Only if there are other areas of deficiency!
