#11 |
![]() Join Date: Mar 2007
Pete,
When you say 118-120...is that one Drag radials or Street tires? LGAFF 92 ZR1 #234 |
#12 |
pete , so you are running the stk fueling.? after porting myinj housings and plenum, my air fuel on the dyno went to 13.9 to 1. how do you combat the lean condition/ my car detonated like crazy on the first dyno run. which was why corey took 2 deg of timming out over 4500 and added fuel to get the air fuel down to 12.8-12-9 to 1.
#13 |
paul , my modds are as follows , jeal headers ,fidanza flywheel, corey henderson ported inj housings and plenum, as well as prom tune , 410 gears, z industries reverse air cleaner,flowmaster exhaust .car trapped 117.5 best with this set up , them had spin tec custom do a exhaust for me and it now trapps 118.5-120
#14 | |
![]() Join Date: Nov 2007
![]() Soooo..... Among other things, I would like to veer away from that 14.0:1 A/F ratio before doing the top end and headers. ![]() P. Last edited by Paul Workman; 10-19-2008 at 10:53 PM. |
#15 |
![]() Join Date: Jul 2007
I have a comment..
on that dyno run where was the Wideband O2 placed? I will assume tail pipe, if that is the case, don't you also have Cats? I am pretty sure the Wideband may not be as accurate as you think after the exhaust goes through the cats..
#16 |
#17 |
videos on u tube that show some of the actual runs are under bradley taylors zr1 at famoso
#18 |
#19 | |
Originally Posted by Pete
Paul,with a good ported top end (plenum & IH's) headers and good flowing exhaust our Z's run 118-120 MPH. Even with ported heads and stock cams i would not mess with the feul tables. Pete Quote:
That along with the plug cuts I did led me to believe that even tho my dyno run showed a 12.8-.9 AFR at WOT, I decided to try "leaning" out the A/F at the top. The way to check AFR is to have the WB located at the collector and prior to the cats. |
#20 |
![]() Join Date: Dec 2003
Paul,definately something wrong there,i would put the WB before the CATS and take it from there,also the some dyno WB's could be way off.
Most all stock LT5's get a little fat around peak torque and leanout at the top but your #'s are way off. I would try another dyno or WB. Recently i dyno'd with tailpipe WB and collector WB between both WB's there was .5-.7 differance at the collector it was showing me 12.3-12.8 at the tailpipe it was showing higher 12.8-13.5 Now which one do i believe? I chose a happy medium. I played with AFR's and to my suprise anywhere between 12.5-13.2 i did not see any gains, believe me i tried. I like to be a little fat 12.5 at around peak torque a bit leaner 13.1 at the top. I will have to dig up some of my old dyno sheets. I was running 118-120MPH on GS-C's (ported intake,headers,old B&B) but would need a clutch after a day at the track. ![]() I notice if you get good traction MPH goes up. If you guys are going to the track with street radials and are looking to run consistent ET's/MPH you'll be pulling your hair out. I know of a 350ci ported everything,headers good flowing exhaust,stock cams making good power with stock VE tables running 122-123 MPH in circles of course on DR's. I bet if you guys put DR's on your cars they will run more consistent and good MPH. If i get the time i would love to take on project ZR-1 start from scratch i.e. Jeffs ZR-1 from stock to headers/good flowing exhuast to ported intake then ported heads (stock cams). Jeff,of course you would have to pay for dyno's gaskets/parts etc. ![]() What do you say Jeff,that would make for a good article. Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 10-20-2008 at 03:03 AM. |
