#11 | ||
#12 | |
![]() Join Date: Aug 2006
#13 | |
![]() Join Date: Apr 2004
What I'm planning to do is level two cinder blocks on my garage floor. I was then going to jack the rear wheels onto the cinder blocks and take some measurements to the floor. I'm hoping to figure out "what" is out. I figured I'd do this with the factory bolts. I don't have the "lowering" bolts yet. It doesn't appear I'm going to be able to find them locally. Has anyone seen the rear end out of level by over an 1"?!?!?!? Last edited by HIZNHRZ; 10-17-2008 at 04:24 PM. |
#14 |
Yes I know the measurements are very course but they do allow one to visualize the problem. The pictures are on a car with ~10K miles that until recently was a stock garage queen. The spring "adjustment" bolts are stock and the castle nut and cotter pin is in the same place on both.
Drivers side: ![]() Passenger side: ![]() Last edited by HIZNHRZ; 10-17-2008 at 08:03 PM. |
#15 | |
While I realize lowering/raising affects the suspension geometry, well he's trying to make them even. If the ride heights are the same but the spring bolts are not, does it matter? Won't the spring rate still be the same on each side, meaning it will take X amount of lbs of force to compress the spring/suspension an inch (where X is the springs rated rate). If you tighten the nut up, you aren't compressing the spring more, rather it will raise up the car by the same amount, correct? So it's not getting pre-compressed or anything? Or am I thinking about it wrong? Also, is it correct to say the spring raises the car from the middle (more or less), which is possibly why side-to-side it can have some variation? |
#16 | |
#17 |
You can not take measurements there.
Proper measurements are taken from the frame rail to the ground. As body panels are not always applied or installed in the same position. |
#18 | |
"a problem". I guess I am doing a poor job of providing information that might allow one to visualize the issue. If it were your car and when it was sitting on a level surface the space above the rear tire on the passenger side was one inch greater than the same space on the drivers side, what would you do? Thanks in advance. |
#19 | |
Has the rear sway bar been off this car at all?
How did it look before you swapped the wheel/tire combo? Quote:
#20 | |
I never really noticed the problem with the 17 inch Amolds and Michelins or with the sawblades and GYs. I'm in the process of pulling out some old pictures to compare. |
