Old 10-15-2008   #11
Chris_32212
Default Re: Intermittent digital display in the dash
maybe if i am lucky, my display will decide to work tomorrow and then i can use the paper clip method. ...but then, would it even tell me there is a problem? lol.
Old 10-15-2008   #12
Jeffvette
Tech 1 is roughly about 500 bucks for a complete unit with cartridges.
If your display is working press the trip/odo button until you see 1.1 in the lcd panel. Then hit eng/met to enter. You can use inst/aver to scroll. A C12 indicates no issues. Then you know you have a wiring problem.
Old 10-15-2008   #13
Chris_32212
i will give this a try in the morning
[SIZE=1]1993 Corvette ZR-1 #137, 1990 Yellow 6speed coupe, and 1991 6speed coupe.[/SIZE]
Old 10-15-2008   #14
Thumbs up Re: Intermittent digital display in the dash
It's about a 30-45 minute job to pull the panel out.
Hmm after you drop the steering wheel, driverside Hush panel, Steel reiforcement panel, IH Bezel for the first time.... Maybe... a better estimate is about an hour and 15 minutes and one beer lol
Old 10-15-2008   #15
Chris_32212
there is a guy i know that has a standard corvette coupe dash cluster panel for a C4. is the digital display portion removable? would the digital display from that C4 coupe dash cluster work in mine?
Chris
Old 10-15-2008   #16
With the exception of the tach the digital display for the MY92-MY93 is the same. I am not sure if that piece only can be pulled from the IH group maybe Jeff knows
Old 10-15-2008   #17
Chris_32212
i still need to find a damn paper clip. lol
Old 10-15-2008   #18
Chris_32212
jeff i did what you said to do here on holding the trip/odo button but i pressed and held it and it just kept flipping back and forth from odd to trip. i cant get to that menu with the procedure you listed
Old 10-15-2008   #19
Jeffvette
Make a "U" shape out of the paper clip. Hook one end into the A port on the ALDL and the other end into the G port. Turn the key to the "run" position. This will enable you to enter the CCM diagnostics. The CCM will automatically start cycling through the modules and codes with pauses in between each one. It will give you this information where the digital speedo is.
Old 10-15-2008   #20
gbrtng
gbrtng's Avatar
From what I'm hearing, the displays suffer from failure due to cold solder joints. Pull the display and carefully look for crystallized solder joints and re-solder with a small iron (if you're really brave). Else send it to
http://www.instrumentclusters.com/
for repair. They got my 91 L98 car's working fine after I got tired of fooling around with it for many years. Wifey is happier now that she can see the gas gauge.
