Old 10-06-2008   #11
bldavis11
Default Re: Engine Parts
Okay, I'll bite. If we're going to make the bolts, I can pitch in for a set.
bldavis11 is offline   Reply With Quote
Old 10-07-2008   #12
LGNDLT5
LGNDLT5's Avatar
Looks like the prior owner of my block may not be able to locate the head bolts.....was wondering if any knows of sources or am I stuck with paying Kurt White $47 per bolt.
Also will be looking for coolant tubes and an air horn as I move forward.....may need to find head bolts first.
92 ZR1
#234
I have the coolant tubes, OEM gaskets and the airhorn available, all NOS. Unfortunately not the head bolts. Let me know if you need them and we can work out something reasonable if desired. John R. Sullivan 847-275-4841
LGNDLT5 is offline   Reply With Quote
Old 10-08-2008   #13
I'm going to share a conversation I had with Graham Behan last May about this subject.
As I recall, Graham said they never actually measured the bolt length when installed, cold or hot. Due to the higher thermal coefficient of expansion, aluminum vs steel, the bolts will incur higher axial tension at engine operating temps than when installed at ambient conditions. Determining the difference in length would require flat grinding the ends of the bolt and using a sonic instrument to measure the differential length, cold to hot. With that information, stress on the bolt can be calculated to see if yield strength was exceeded. It could also be obtained by accurately measuring the length of a new bolt at std temp with a micrometer before install and again after it was removed from a heat cycled engine. If the length is greater after use, that would be an indicator of permanent deformation, and therefore exceeding yield strength of the bolt.
I came away with the impression that replacing the bolts after 1 use was an insurance policy factor as opposed to empirical testing data.
Would be interesting to know about head replacements with used bolts & the results.
Jerry
Old 10-12-2008   #14
phrogs
phrogs's Avatar
I have a used set of head bolts if your interested.
Oh and I have never bought new bolts for the motors I have $50 a bolt I know im not the only one to reuse these head bolts
JOHNNY P
Currently own
Old 10-13-2008   #15
I sent a note to ARP to see if they can reproduce the head bolt....more to come.
92 ZR1
#234
Old 10-13-2008   #16
Polo-1
Ron Woods has the ARP studs. They are pricey $1250. they are made from the ARP 2000 rod bolt material. Im sure thay could have been made from 8740 moly and been much cheaper.
Ron and Randy's stuff is pretty top notch stuff.
http://www.zr1products.com/vendors.html
Old 10-13-2008   #17
Holy Chit!
$1250 thats about what I have in to the entire motor
92 ZR1
#234
Old 10-13-2008   #18
Polo-1
$50 x 20 = $1000.00 for non reuseable bolts.
Old 10-13-2008   #19
flyin ryan
flyin ryan's Avatar
ya...i was going to say something earlier. i've had ARP make me custom stuff lots of times & it's never cheap. they can do whatever a person wants but the super small run (volume) stuff ain't cheap. we get too used to their fasteners in the catalog that have part numbers attached, which are reasonable in price, IMO, but they sell hundreds of thousands of them to make up for it.
Old 10-14-2008   #20
ARP says they have nothing that fits our application, they are asking for measurements....my guess is someone out there has these, any volunteers to give me the info?
I will e-mail quesitons to you.
92 ZR1
#234
