Old 09-24-2008   #11
Aurora40
Aurora40's Avatar
Default Re: injector problem or coil pack problem?
How was the fuel pressure? What did the #1 plug look like? You might also check the FPR's vacuum line to see if there's gas in it.
You can buy a spark tester for like $10, they sort of look like a spark plug but with a weird end.
I wouldn't think only one cylinder down would be as bad as the symptoms you are describing.
Bob Saveland
Former owner of #2517
Old 09-24-2008   #12
Jim Nolan
If it is the injectors they must be in very bad condition. When I pulled mine for the porting my secondaries were very corroded, but my ZR1 ran very good and never burped once.
Old 09-24-2008   #13
Mine were rusty as hell as well. Wont happen with RCs as they have a stainless steel insert.
Old 09-26-2008   #14
Injector #1 was bad...
Jim said from day 1 what it was and sure enough!
Old 09-26-2008   #15
Actually I did in post #2 but hey its up and running. But I would still my FUs complete set
Old 09-26-2008   #16
Thanks for the mention Daryll
Plus all the proceeds go to a great cause.And if you have a a 90-92 , your going to need them sooner or later .
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 09-26-2008   #17
QB93Z
QB93Z's Avatar
Follow up on the problem:
The symptoms were: loss of power, rough, stumbling operation, stalling at idle, hard to start, and white smoke at the exhaust that smelled like gasoline.
Pulling spark plug wires showed no change in rough idle for #1 plug wire. All other plug wires made the idle worse.
Fuel leak down test: ignition key to on, fuel pressure steady at about 50 psi. Ignition key to off, fuel pressure immediately dropped to zero.
Pulled the Plenum. Turn the ignition key to on, observed fuel squirting from #1 primary injector.
We replaced the bad #1 injector with a used injector to get the car running again.
Old 09-26-2008   #18
Jagdpanzer
Jagdpanzer's Avatar
Well done skipper, I hear by promote you to honorary Engineman
Old 09-27-2008   #19
HIZNHRZ
Here's the link from Marc Haibecks website for isolating bad fuel injectors. All you need is a digital multimeter and the ability to follow the instructions. Bob and I used it a little over a year ago. It gives you the ability to determine if any others are on the way out.
http://www.zr1specialist.com/HAT%20W...in%20Place.pdf
Old 09-27-2008   #20
QB93Z
QB93Z's Avatar
Thanks for the link. The injector failure that occurred was mechanical (stuck open), so it did not have an electrical problem that we could have measured.
