#11 | |
#12 |
![]() Join Date: Mar 2007
![]() ![]() My cost: 3/8" hose(10ft)-$8 3/8 Brass Hose repair nipple: $2 Husky Compressor filter =$15 Grand Total= $25.00 LGAFF 92 ZR1 #234 I think Pete said he is running an old bong he converted to an oil catch can, now you know why his car runs so well.....its very happY ![]() |
#13 | |
Now, I know you next question is going to be, why are you catching oil. Well oil will pool in the plenum and get sucked down into the runners. Too much oil and you get detonation issues. |
#14 |
I was doing it to reduce emissions, and save the environment.
LGAFF 92 ZR1 #234 |
#15 | |
Time to talk about that Ocean front property in Arizona I have for sale. ![]()
#16 |
I will post some pics, I need to mount it and shorten the lines. I ran the line from the back of the plenum, over to the booster, down the inner fender, and into the front bumper area. Then back up the same way, the filter is black so it blends in....nothing too spectacular, any idiot could do it....this one did.
![]() ![]() LGAFF 92 ZR1 #234 |
#17 |
i was under the impression F.I. and large stroke applications typically generate more cranckase pressure to use these...Learn something new every day.
LGAFF, nice of you to save the environment like that. Make sure and drain your oil down the toilet next time to save water. ![]() |
#18 |
Here is the catch can, I still need to make a bracket, and cut the lines to fit.......so keep the smart*** comments to a minimum......Jeffvette where's the kit for this?
#19 |
Locobob has had one for a couple of years now. Nobody has ever expressed interest.
#20 |
Humor not allowed.
Good luck with your project. |
