Old 08-04-2008   #11
onemajesty
Default Re: Rough idle and no power,
I have all most the same problem, can you show me we that hose is????
94' that just about starts & has very little power. .
Was looking forward to Carlisle in a few weeks, therefor I was out getting the 94' with 4K. ready togo, and the car has decided to make some changes on it's only. . Until now the car has ran very well, every couple of mths. and it ran good for the first couple of miles today, after I shut it down then restarted it, that's when the problems begin to happen.
Now-it just about start, and has very little power and act like it going to back-fire / misfire.
Thinking I had water(in the tank) or bad; I sucked most of the gas out of the tank as much as possible (down to 1-bar) then put fresh 5-gals, & some Marvel Mystery oil that helps clean fuel areas.
The fuel injectors have be change a couple a years back.
I don't know where to go from here, any help will be much appreciated.
[IMG]http://images.*************.com/images/smilies/bigear.gif[/IMG]
Kevin
onemajesty is offline   Reply With Quote
Old 08-06-2008   #12
ZWILD1
ZWILD1's Avatar
The hose is right behind the plenum. It holds the two PCV valves, and is connected to both of the injector housings. A leak could cause rough idle and excessive blow by. Your problem sounds more like a fuel problem. I would start there.
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
