Old 07-29-2008   #11
902066
Default Re: Gonna need a heater core...
How do you temporarily bypass the heater core? I have had my ZR-1 for 8 years and never used my heater or defrost. I would like to bypass it before it starts to leak, and someday if I need a heater, or sell the car reconnect it. Thanks
902066 is offline   Reply With Quote
Old 07-29-2008   #12
Default Thanks! Now, carpet cleaning??
I'm looking forward to tearing the dash apart about like "going to the woodshed". But! I do driver 'er a little in the winter on sunny, dry days and a defroster and warm toes are nice. SO...I recon I'll bite the bullet and change the SOB and be done with it. But, I may bypass it until cooler weather arrives - hadn't considered that, Hans...Good suggestion.
Other than lots of distilled water and a wet/dry shop vac, any suggestions on getting the antifreeze out of the carpet???
TIA,
P.
Old 07-29-2008   #13
Originally Posted by Jeffvette
It is the same as the L98 car. 52479882, it's still available from GM.
Thank you, Jeff, for looking that up for me!
P.
Old 07-29-2008   #14
Default Re: Thanks! Now, carpet cleaning??
TIA,
P.
Paul, what color carpet is in your car? Also the dash is not TOO BAD to remove, but it depends on what the book says too. I thinkt he dash pad has to come out, but again, I may not be able to drive downa nd help,m but I can guide you through on some things
