Old 06-24-2008   #11
Default Re: Do these spacers make my AZZ look big?
Originally Posted by LGAFF
PS no comments on the exhaust being crooked, these things won't line up worth a@#$@!
Are they tack welded at the back? if not I can probably give it a go to get them better..
Mine are not as bad, but I need to cut the tack welds to fix them
Old 06-24-2008   #12
No they are not tacked, trying to line these up is near impossible, however it seems some bending is in order, they have been off since I bought the car. Maybe replacing the exhaust clamps would also help, they were reused when the X-Pipe was put in.
92 ZR1
#234
Old 06-24-2008   #13
carter200
carter200's Avatar
Dave,
Custom is the only way to go and people like me have a way better quality control then the big shops. Take care, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 06-25-2008   #14
HADI-ZR1
Lagff ,
1- the exhaust problem?? i have same as you with my BB !
the soulution : remove it and have fun .
2- $170 for spacers .come on. i bought mine for $60 from ebay
the spacer are 1.5 inch to cover my custom wide rear quarter with rear callaway azz!
3- is the pink vette, stock or moded
Old 06-27-2008   #15
SDZR-1
Well now i feel better....i bet i worked a solid 2 hours trying to get my borla symetrical on both sides and finally got it as close as I could and quit. I looks ok at best...but i alway notice it.
SDZR-1 is offline   Reply With Quote
Old 06-27-2008   #16
Zr1 Destroyer
Zr1 Destroyer's Avatar
Hey....your exhaust isn't straight...lol..j/k!
I lined mine up(after going through a bunch of different clamps) the best I could a simply tacked it with a welder.....it has never moved again!
Zr1 Destroyer is offline   Reply With Quote
Old 06-27-2008   #17
carter200
carter200's Avatar
Originally Posted by Zr1 Destroyer
I lined mine up(after going through a bunch of different claps)
Now that sounds like a problem..........
Old 06-27-2008   #18
HADI-ZR1
I saw you Zr1 Destroyer!!
Old 06-28-2008   #19
Zr1 Destroyer
Clamps....
Old 06-28-2008   #20
HADI-ZR1
Clamps....
Still you can use them!
