06-22-2008 | #11 |
Re: Car running like $hit.
I replaced the plugs today and drove it with no problems.Im going to figure on replacing the injectors sooner than later.While Im at it Ill replace the coils and a set of new G.M. replacement plug wires.Id like to have a set of original wires but Im not going to pay $400+ for a set of wires,not me.Thanks for all the tips guys,greatly appreciated.
06-22-2008 | #12 |
not sure if you are interested ,but msd makes a very good set of wires for our cars. very low resistance .
06-22-2008 | #13 |
Jeff, I have to agree with your game plan.....not trying to spend your $ for ya...but it's the old "while we're here" rule.
Plenum is off for whatever.....do the right thing before closing it up.
06-22-2008 | #14 | |
Never say never...
Resistance is significantly higher on the compression side cylinder, so in a "gray" situation it is possible, to have that experience if the plug circuit resistance on one side is unbalanced. I would expect, however, that in most cases both plugs would experience some misfire - trading back and forth, especially under heavier loads. So, that is why I said, I would "put the coil at the back of the line", as far as suspects go: Not to be dismissed, how-some-ever. P. |
06-22-2008 | #15 |
The miss is back,its injector time.Once I find out which is the best injector Ill start rippin.
