Old 05-07-2008   #11
Default Re: Stainless Works headers
Originally Posted by tf95ZR1
I was lucky and found a set of Jeals. Not only fit well and good clearance,
but could use the stock oil dip stick tube and oxygen sensors.
That was not the case for Jerry who had some issues with his Jeals.
Sounds like its just the luck of the draw.......
Well I hope I get a good draw as I have yet to install them but they came of of Todd C s car so im sure they should fit. Tucked away in the garage for a next big upgrade.
Old 05-07-2008   #12
Nick
Wow, somebody at SW had a bad day. Reminds me of all the swearing and hammering we did when we installed your headers all those many moons ago, Jeff.
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
Old 05-08-2008   #13
Jerry#397
Jerry#397's Avatar
Jeff,
The problem I had with the "new" Jeal Headers I just installed was the location of the drivers side 02 probe, it hit the bell housing. Had to grind quite a bit to get it in and give about 1/16" clearance. And one other problem area for the Calif. guys is the location of the EGR tube, it would not allow me to put in the top bolt on the K brace on the passenger side; had to remove the header, install the K brace then reinstall the header. And I could not intall all the bolts on the passenger side front port although I have no leaks.
Jerry
Jerry#397 is offline   Reply With Quote
Old 05-16-2008   #14
Jeffvette
I just wanted to give an update, seeing as how panties are in a bunch over at CF.
Headers were received by SSW on Monday 12th. I had to call and ask for an update on the 14th. They agreed the primary tube #1 was sticking out further than it should, and they were inspecting the cnc pattern on the flange for any issues.
As it stands, I have been doing the one calling to get info. I am about to call now and get an update on the flange issue.
Old 05-16-2008   #15
ZR WON
Jeff:
Don't know if you waded through all the BS on CF to see my post... If you have not done this already, contact Al Noe. He is basically Mr. SW's. When I was selling the headers to our community, he took care of any issues with incredible timeliness. Hope this helps.
Regards
Brian A.
90 ZR-1
12.09@118
01 Z06
not quite stock
ZR WON is offline   Reply With Quote
Old 05-17-2008   #16
95ZR1#418
95ZR1#418's Avatar
Jeff-
FYI- I installed my SW's in Feb 2004. Perfect fit, tight- but as you would expect with any application takes time to get all the bolts in. Love my system!
Definitly a production problem since '04 anyhow
Later-Bob :D
[IMG]http://www.axoplasmic.com/800x600/toponzr1.jpg[/IMG][IMG]http://www.axoplasmic.com/800x600/topoffzr1.jpg[/IMG][URL="http://axoplasmic.com/AXOPLASMIC/ZR1.html"]My '95 ZR-1 Home Page[/URL]
95ZR1#418 is offline   Reply With Quote
Old 05-17-2008   #17
bradslt5
Originally Posted by Jerry#397
Jeff,
Jerry
new jeal headers?????? is someone making these now?
Old 05-17-2008   #18
95ZR1#418
95ZR1#418's Avatar
Jerry-
In '04 I had 1 chance to buy a set of Jeals, as far as I know they were the last available set on the planet offered by Cory Henderson........I've never heard of them being available since then, they were offered to me at 3 times the price of SW's hense my decline. I fear you will only find them available as used, and as of this date I've never seen a set available.
There are custum headers available today other than SW & the defunct Jeal which you can pursue, they will even hook up your AIR to them, find them using Google, may cost you a couple thousand but you'd probably love'm.
Later-Bob :D
Old 05-17-2008   #19
Jerry#397
Jerry#397's Avatar
Guys,
I bought them off of e-bay, they were advertised as new with all the parts that came with them. Did the guy in Texas that owned them tell the truth? A number of folks saw them and bid as I did, just kept bidding until they were mine, $1050.00.
Jerry
Old 07-15-2008   #20
Jeffvette
Just to wrap up this discussion, SSW put the header back on the jig and the #1 pipe was not welded correctly. They sent out an updated set and everything installed perfectly. Car was a little late to the customer, but he understood and the weather was also crappy.
