Old 04-16-2008   #11
lbszr
lbszr's Avatar
Default Re: Had to try it
Originally Posted by -=Jeff=-
You I just realized i should expand my previous comments.. run the Xpipe, sfter the X pipe ( before the bends) run a pair of Magnaflow bullets.. then run the B&B Mufflers.. it gives a non neck down solution and the Bullets muffle the sound like the resonator did
I didn't actually find the Magnaflow but ended up with Dynomax bullets and since there was no x-pipe laying around deferred that and put in a H pipe instead to equalize sides, still might try xpipe later but it sounds pretty good now and the drone is a lot better, maybe a little louder than the B@B resonator was and with no choking down. Thanks for the bullet suggestion.
Maybe I can get some hearing back now.
Old 04-16-2008   #12
DOH.. Yeah Dynomax are the bullets, you got it.. damn I am getting mixed up, must get getting old.. LOL
whatcha doin with the resonator now?
Old 04-17-2008   #13
lbszr
lbszr's Avatar
After getting a good dyno run like it is now probably put the resonator back in and compare since it is a little quieter with it.
