#11 | |
![]() Join Date: Dec 2004
http://www.zr1netregistry.com/Old_Proj/old_proj7.htm Just a fwiw on the clearing of the codes after the issue is addressed, cleaning up the ground problem on the sensors. I did both as a pre-emptive play. I found that clearing the codes was the hardest part of the whole deal, for me. It seemed to me that timming the grounding and un-grounding was my problem. I used a door bell as my way of doing the grounding and un-grounding so I could use my watch's second hand to time the events. ![]() Tom
#12 |
Eric, did you ever get the codes?
#13 |
![]() Join Date: Apr 2009
Jeff, No i did not get the codes. I tried but it look like it was giving me multiple codes. maybe a 42. i'm going to try again today.
Tom, thanks for that post it helped me see what i'm up against. Eric |
#14 |
OK, I checked the codes again and it is definitly is a code 42. any idea what a code 42 is?
#15 |
42 Indicator lamp circuit; Open circuit
Double check again. |
#16 |
12 12 12 42 42 42 12 12 12 and the battery is dead.
Thanks for your help Jeff. |
#17 |
Eric, do you have a FSM for your yr ZR-1?
If not I have a 90 Z so I have the 90 Helm FSM. I can call you with the info from the mnanual & try to get you going in the right direction. just a fwiw. ![]() ![]() Tom
#18 |
Thank you - I do have 93 FSM's, but I am going to give up and take it to Jeff at PNWZR1. One of the luxuries of living in the Northwest. Thanks again for the offer! Last edited by Eric870; 04-10-2009 at 08:58 PM. |
#19 |
![]() Join Date: May 2008
I have the same problem with my '90. Thanks for all the info. I'll be taking care of the problem whenever I get a chance.
![]() 1990 ZR-1 S/n 1096 |
#20 | |
