Old 03-10-2008   #11
Aurora40
Aurora40's Avatar
Default Re: blk car is mad at me no start city .....
Well if your security light is on and it's throwing a code 46, I personally wouldn't bother with the clutch safety switch. It would seem to clearly be a VATS problem.
Try cleaning the contacts on the key, and retry it. Possibly the pill is worn too much, though in my experience this results in intermittent problems, not just one day it no longer works. That's when I get a new key.
Bob Saveland
Former owner of #2517
Old 03-10-2008   #12
IowaZR-1
IowaZR-1's Avatar
How It Works
The idea behind it is very simple. The ignition key has a "chip" (just a resistor) installed on it, which can be easily seen. When you attempt to turn the ignition ON, the resistance of the chip is measured, and compared to the value stored in the VATS decoder module. If they are the same, a signal is sent to the ECM telling it to fire the injectors. At the same time, the starter enable relay will be energized by the VATS decoder module. If the wrong resistance is read, then the signal will not be sent to the ECM, the starter enable relay will not be energized, and the injectors will not fire. Additionally, a code 46 will be shown. This code will not be stored in the ECM's memory, and is only present while the conditions for a code 46 are present. The module will shut down for 2 to 4 minutes. During this time, any attempts to start the vehicle will not work. If the ignition switch is turned during this time, the timer will restart even if a key with the correct resistance is used.
IowaZR-1 is offline   Reply With Quote
Old 03-11-2008   #13
bradslt5
thank you so much to all that helped . it turned out to be the key pellit on one of the ignition keys was bad . disconnected the bat for a while and put the new key in and there was that sweet sound of her running. I am happy again.phew
Old 03-11-2008   #14
tccrab
tccrab's Avatar
Everything you never wanted to know about VATS.
VATS SUCKS
http://www.joestradingpost.com/vats/
TomC
'90ZR1 #792
Honorary Pirate
[/B]
