03-24-2008 | #11 |
Re: Here is 1990 #566
Hi Pete...
For the 'Power Plate' you can get at Mid America Motorsports>> http://www.mamotorworks.com/corvette-3-54-1054.html The throttle body "plate" actually replaces the OEM plate and is not a add on badge... but it is a beautiful piece of machining and is not hard to replace (just be carefull about removing the OEM plate so as not to damage the gasket). Here is a thread I started on the plate replacement DIY>> http://www.zr1netregistry.com/forum/...ight=carter200 In that thread you will note plate source (Carter).. Michael
Michael :cheers: [I][SIZE="2"]1990 RED on RED #566[/SIZE][/I] [I][SIZE="2"]WAZOO MEMBER[/I][/SIZE] |
03-24-2008 | #12 |
Thank you very much for you help Michael
Does Carter still sell those plates? I thought all ZR-1's had that factory part installed but now I've realized it's some kind of beautiful add-on I already ordered the 'power plate' but I'd like to replace the ashtray & lighter cap itself, the painting is faded and I think it's not a good idea to stick the plate on a bad looking cover Do you where to find one? Last edited by EuroPete; 03-24-2008 at 10:50 AM. |
03-24-2008 | #13 |
I would start with Ecklers>>>
http://www.ecklers.com/search.asp?ac...insert%22+%3B+
