Old 02-19-2008   #11
Jeffvette
Default Re: How to calibrate the tac??
VSS is only used to calculate speed, nothing else.
Old 02-19-2008   #12
Tiz a std 3.45 gear. That wouldn't affect the tac, as others have indicated.
Old 02-19-2008   #13
DaveK
ahhh okay - I thought the vss signal was used on both, my mistake
1991 #1516 Black/Black
davidmkelly.com
Author of fast-paced, sci-fi thrillers.
Old 02-20-2008   #14
I have seen this on a 90 ZR1, the problem was in the instrument cluster which had to be pulled and repaired. I would ask a local Chevy dealer where they send their warranty electrical repairs.
Tom is offline   Reply With Quote
Old 01-17-2009   #15
Jarek5_7
mine tach in 1991 read twice as real rpm ;(
Jarek5_7 is offline   Reply With Quote
Old 01-17-2009   #16
WVZR-1
Tach calibration is done on the "main board" in the cluster. I've had conversations with a fellow who likely can accomplish it but he's not into the C4 clusters presently. He's pretty close to me and has offered to look at mine and with snapshots I've provided he's agreed with me which capacitors/resistors are responsible for the calibration. I just haven't had the opportunity to let him have at it. He does early stuff for many of the "resellers". The resellers that sell other than his product send theirs to him to correct when the one they sold fails.
The cluster can be sent to several cluster re-builders for the calibration and they usually come with a 1 yr warranty. There's not as many authorized service centers as there used to be but there are "responsible" people out there. A build should be something $235 to maybe as high as $350.
The error is sometimes conversational. When I bought my car I was told "stock everything". Seat of the pants it sure felt like it was "stock" but the tach reflected something that would have led a person to believe it had a gear! I checked it with my Tech1 and confirmed the error.
If you've an "error" now it will likely get substantially worse.
The tach can also be calibrated with a "box" similar to a Dakota digital. A plus to this would be you could occasionally re-calibrate it yourself. I've had conversations with a builder and it seems quite easily accomplished.
Old 01-17-2009   #17
gbrtng
gbrtng's Avatar
Check with these guys
http://www.instrumentclusters.com/
to see if they can "calibrate" a tachometer. They repaired a 91 cluster for me and
their work is good.
The tachometer is just an analog gauge which gets its input from the ECM - it's kind of like a voltmeter.
And the tach reading has NOTHING to do with the rear gears.
Old 01-17-2009   #18
WVZR-1
their work is good.
If your reference is to my post here's an example:
2500 RPM / 3.45 gear / 1-1 (4th) / 25.7 tire = maybe 110 MPH,
2500 RPM / 3.90 gear/ 1-1 (4th) 25.7 tire = maybe 98 MPH
If your car (stock) is at 2500 RPM in 4th gear and the speedo is something substantially less than 110 MPH with no speedo error there can be only a couple explanations, it's had a gear installed or it's got a tach error. Mine were numbers similar to these and I confirmed the tach error with a Tech1 reading both speed and RPM from ALDL connector. I didn't SAY the rear gear effected the tach's accuracy.
The Tech1 confirmed the "tach error" and also the fact the car I bought was "stock" at least in respect to the rear gear ratio.
Old 01-17-2009   #19
gbrtng
gbrtng's Avatar
My post was not in response to yours. Yours hit the list while I was typing.
Old 01-17-2009   #20
The issue with our tach, like all the other electronic tachs since at least 84 is that the damn thing is slow to react. Get a shift light.
