Old 03-10-2007   #11
RiceEatingZR1
RiceEatingZR1's Avatar
Default Re: Lifter Tick??
hmm I think my car might be starting to make the same sound. I had it stored away for winter and turned it on today and heard the sound. Did you ever find out what caused this? if not if you want send me your video and I will upload it. email: shaun.richmond@sbcglobal.net
-Shaun
1991 Charcoal Metallic ZR1 #730
[URL="http://www.cardomain.com/ride/2649606"]http://www.cardomain.com/ride/2649606[/URL]
[URL="http://community.webshots.com/user/shaun91zr1"][/URL]
[IMG]http://img.photobucket.com/albums/v211/RiceEatingZR1/Forum%20Sig/Sig1.gif[/IMG]
RiceEatingZR1 is offline   Reply With Quote
Old 03-10-2007   #12
91King
91King's Avatar
Last year my car developed a ticking noise about two weeks after I changed plugs and wires. The ticking noise sounded like lifter tick, but it turned out to be a hair line crack in the insulator on the number 5 plug. Replaced the plug, ticking gone.
91 red/red #1813
EES 402
91King is offline   Reply With Quote
Old 03-11-2007   #13
RiceEatingZR1
I used a piece of wood as a stethescope and put it on the cam cover and could not hear it but when I was able to put it on the fuel Rail I was able to hear it better. I just had the injectors replaced about 2 years ago now. could it be a bad injector?
-Shaun
Old 03-11-2007   #14
jonszr1
jonszr1's Avatar
when you replaced the injectors did you get the factory inj. or did you go with another company like accel or rc? If you used the factory ones then yeah could be going . factory injectors don't like todays fuel
Old 03-11-2007   #15
RiceEatingZR1
Yeah I got RC injectors
-Shaun
Old 03-12-2007   #16
RiceEatingZR1
I took some Video of my car running so that maybe it will give you a better understanding
http://smg.photobucket.com/albums/v2...nt=zr1tick.flv
-Shaun
Old 03-12-2007   #17
Jeffvette
Kind of hard to tell over the PC, sounds pretty damn choppy. Check the oil level to see if you are running a bit low (will cause lifters to make noise) Add oil if needed.
Get a real auto stethescope place around cam cover over each lifter hole, and then you can reach the driver side tensioner to check for excessive noise as well.
Old 03-12-2007   #18
jonszr1
jonszr1's Avatar
shaun , were you the one that was haveing trouble getting your car running after replacing head gaskets?. have you tried pulling the plug wires one at a time with it running and see if it stop? you might give the rc guys a call and ask them if their inj might make this sound if one is partially plugged ? i listened to you vid and something tells me it might be a plug wire .its my best guess hope that helps.
Old 03-13-2007   #19
RiceEatingZR1
I didn't have a head gasket issue.. but I am going to pull the Wires and check plugs. I was thing about replacing them with some NGK plugs anyway. thanks for the advice .
-Shaun
Old 03-13-2007   #20
jonszr1
jonszr1's Avatar
be very carefull when gapping them as that little tiny tip breaks very easy ( found out the hard way) I set my gap @45 with a gap ring . you also need the wire gapper for bending the strap. I found that the gap out of the box was between 60 -70 thou and thats too big . Ps you have a very nice engine compartment . did you get her pcd?
