01-21-2008 | #11 | |
Re: While I'm pulling the plenum....
01-21-2008 | #12 |
I'd leave the stock coils in there if everything is working as it should now. Once you get through your first (or second!) plenum pull, you'll see how really easy it is, and if you have a coil pack failure in the future, your plenum pull learning curve is not an issue.
As for the injectors...its only a matter of time...
Nick ZR-1 Net Registry Founding Member #32 - lapsed... |
01-21-2008 | #13 |
I would do the injectors just to save yourself the headache of having to pull the plenum agian. THat day WILL come if you stil have the Multecs in there .
1990 ZR1, 142,000 miles-Black on black 4.09's Haibeck chip, 3"exh, K&N, meth inj. |
01-21-2008 | #14 | |
Re: "Secondaries"??
I gather you're referring to the secondary throttle plates?? That requires a chip change (to switch on the secondary injectors), no? I imagine the secondary injector relays can be "hard wired" too, in a pinch and willing to compromise, yes? Lemmeno, cuz I'm one of about four newbies on the board about to go plenum diving and I don't want to have to do it again for a good while, if I can. And, if you think pulling the secondary throttle plates is a good I-dear...I just might (to simplify things!) P. PS. Got a chance to air out my Z this afternoon. Boy, what a nice cold aire day will do to the Z...What a BEAST!! P. |
