#11 |
The cleaner is removed via the resevoir but about a gallon of the new PS fluid is pumped in and removed thus displacing the cleaner (all this is done while engine is running and PS unit is pumping so rack, lines and resevoir/pump are all cleaned and new PS fluid installed)
Michael |
#12 |
![]() Join Date: Dec 2004
Hey Mike thanks for the response!
![]() I'll have to look up BG and see who around my neck o the woods does that treatment.....till then I'll keep at it with the turkey baster....it's just so slow & tedious. Seems like I never get caught up with that job!
#13 |
i know the feeling ,but it keeps me busy on cold nights
#14 | |
Personally I hate flush products for that reason. It can be extremely hard to ensure they are completely removed, and often times they are corrosive to the systems they are used in. Just my opinion though. And the risk may depend on the system. Coolant flush left in the coolant might be no big deal as it just rushes through big passages and such, what can it really hurt? ATF flush fluid left in your automatic might be a big deal as there is a lot of sensitive stuff it can corrode. Anyway, like I said, just an opinion. Personally I'd play it safe and just flush with fresh power steering fluid as you have been doing Tom. |
