Old 04-05-2008   #11
Jeffvette
Default Re: Service Ride Control FX3
Tom, Secure the bottom first, if you try to mount the bottom last it can be tricky, it will sometimes be an awkward angle.
Then after the bottom has the nut started, you can then jack up the spindle and tighten the top bolts. Then go back to the lower and torque the large bolt. The upper bolts just won't take the strain of sucking up the suspension.
Old 04-05-2008   #12
Thanks Jeff! That is what I thought. I just was scared by the "!" in the FSM about the "suspension proper trim height" .....over thinking on my part again
Now I can finish what I started last saturday!
Old 12-10-2008   #13
Jeffvette
Updated images
Old 10-14-2010   #14
SDZR-1
I have these codes for my ride control:
Code 13 = Left rear time out
Code 14 = Right Front time out
What does "time out" mean in this case...what is the problem/solution for this?
Thanks,
Jarvis
SDZR-1 is offline   Reply With Quote
Old 10-14-2010   #15
Thanks,
Jarvis
The system is attempting to communicate with the left rear and right front and can not command the shocks to rotate to the left or right. If you have not done a shock replacement recently then ride height of the actuator to the shock is not a problem but a gear inside the actuators has probablly cracked
http://captainzcnc.com/ is a great site for the troubleshooting process.
Old 10-14-2010   #16
batchman
Anyone have a way to thwart the light? I've pulled the shocks and actuators and they're not going back anytime soon.
Of course, I haven't yet looked to see if it gets its' own fuse. What happens if I pull the controller?
Thanks,
- Jeff
Old 10-14-2010   #17
Thanks,
- Jeff
You have four options
1. Put the system back in
2. Put a small piece of electrical tape over the light
3. Remove the DIC and pull the bulb
4. Ignore it
Old 10-15-2010   #18
SDZR-1
I'll investigate....thanks for the help!
Old 10-15-2010   #19
No problem, glad to help. GC
