01-09-2008 | #11 | |
Re: Deleting secondary throttle plates?
1991 Chevrolet Corvette ZR-1 |
01-13-2008 | #12 | |
Is the outboard end of the throttle shaft hole a deadend or does it need plugged as well as the inboard end?
And can they be removed without removing the breather box? Quote:
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT] [FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT] |
01-13-2008 | #13 | |
The outbourd hole is a deadend no plug needed,unless you wanna fill it in with something it's only about an 1/8 inch hole. The breather box does have to come out, unless you don't want your secondary shafts then you can bend the 3 or 4 front ones without taking the breather out. You will probably remove the breather since most leak then you can silicone it and loctite the screws. If you decide to do this and keep the secondary solonoid with vacuum pump then i would remove the solonoid from under the plenum and mount it either close to the differential MAP or vacuum pump with a hard vacuum line they sell at local part stores cheap. This way if it goes bad, no plenum pulling. Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 01-13-2008 at 02:22 AM. |
01-13-2008 | #14 | |
They've been deactivated but secured open, still kicking myself for not removing them last year when the heads were off.
01-13-2008 | #15 |
Shawn,
Does yours throw a code with the secondaries out? |
01-13-2008 | #16 |
I am not sure what exactly needs to be done to remove the secondaries . would it be possible to have someone give me a step by step on the removal process.also i am unsure if one must have their prom reprogramed
