Old 10-27-2007   #11
93 ZR1 Barcelona
93 ZR1 Barcelona's Avatar
Default Re: ZR1 brake lines
Hello.
Genuine GM brake caliper hoses for ZR1 are the following:
FRONT: P/N 10222295 2 required L or R
REAR : P/N 10222294 2 required L or R
Alternatively, you can purchase ACDelco hoses with this part numbers:
FRONT: GM P/N 18032754 - ACD P/N 18J1043 L or R
REAR : GM P/N 18032753 - ACD P/N 18J1042 L or R
Regular C4 brake hoses are different GM part numbers, depending on the Model Year vehicle and if you have heavy duty brakes RPO.
With vehicle VIN number I can send to you exact GM part numbers for your car.
Thanks.
Ramon
And remember....
ZR1 means PUSHROD FREE.
93 ZR1 Barcelona is offline   Reply With Quote
Old 10-27-2007   #12
petefias
Originally Posted by Jeffvette
Standard wheel is the same size/offset as the ZR-1 front.
There probably is a line difference, but it is negligable in the aftermarket hoses. Just make sure you get them pointed away from the tire when you tighten them down.
GBRTNG,
Comparing the 11" wheels vs. 9.5" wheels on the rear of the car the tire would stick out 20mm on the outside and 18mm on the inside (based on 36mm and 56mm offset).
So not all of the width is on the outside under these conditions. That will explain the slightly longer brake line on the Z. If the line is properly turned the standard C4 length line should clear on the ZR1. Would it clear a 335 tire? I wonder.
Old 10-28-2007   #13
gbrtng
gbrtng's Avatar
Originally Posted by petefias
GBRTNG,
I'll make some measurements the next time I have the car on a llft.
Old 10-28-2007   #14
petefias
a i ee ee o oe
