Old 12-01-2007   #11
Jeffvette
Default Re: Valet key switch issue
Originally Posted by TonyTZR1
Hello;
I am new to the site. I just got a 1990 ZR1 and have a question concerning the full power and valet key. The car runs great until put into the full power mode, then it runs crappy. I have no idea what to look for or where. Would appreciate it if someone could give me some direction. I have owned several Corvettes, but not a ZR1.
Thank you
Tony
Tony, I'm guessing when it runs poorly it's when you are WOT. If that is the case, I will go out on a limb andsay your secondary injectors have not been exercised enough and are gummed up.
Old 12-01-2007   #12
TonyTZR1
Jeff;
Thanks for the reply, I will have them checked.
TonyTZR1 is offline   Reply With Quote
Old 12-01-2007   #13
TonyTZR1
Forgot to ask, if the injectors are the case, are they difficult to replace? Iv'e replaced them on my Z06 and that was an easy replacement.
Old 12-01-2007   #14
Jeffvette
Just remove the plenum and the fuel rail. It's best to replace all 16 at once.
Old 12-01-2007   #15
TonyTZR1
OK, thanks again.
