Old 10-11-2007   #11
jonszr1
jonszr1's Avatar
Default Re: Is it safe to use 150 hp shot ??
Hadi ,now thats a deal?????????????????????????????????????????????? ????????
Old 10-14-2007   #12
HADI-ZR1
Originally Posted by ITLGO2
Haid, i'll trade you a turbonator for a windshield
no thanx.
see i also bought new winshield just in case, cuz you know those winshield hard to find!! .
Old 10-14-2007   #13
HADI-ZR1
today i changed the alterantor with light wieght uderdrive pulley and new belt,just after 2 days from my arrive to czech Rep. after 5 days going to change Water P. pulley too.
today i smoke my wheels in every road ,7000 rpm shifting is true life!!
after 3 weeks i am gona miss my zr again....
Old 10-15-2007   #14
GrayZ
Hadi:
glad to hear you are getting some seat time in your
beloved ZR1, of course, you know i was yanking your chain. But, if it's power you are looking for, you might
consider the raptor TT system, once they start marketing
it, I know the owner's are stand up, honest people.
It will do what they claim, once it has been tested.
Enjoy you're car
GrayZ is offline   Reply With Quote
Old 10-16-2007   #15
HADI-ZR1
Hadi:
Enjoy you're car
Hello Bro.
well, i still perfer C/S , i am supercharger guy!
easy to change pulley and play with bost.
it is nice setup Rear TT , but man, did you hear how noizy is that car??
and ppl said that Turbo will reduce sound , COME ON!!!
just fix mufller and go ....
Old 12-30-2007   #16
djpatrick35
djpatrick35's Avatar
Would a 50/75 shot be OK for occasional use? And if so, what is the difficulty level of installing a NOS system in the ZR-1?
djpatrick35 is offline   Reply With Quote
Old 12-30-2007   #17
RHanselman
RHanselman's Avatar
Corey had Curtis Ward's car setup for lots of NOS. I believe he was in the 250 shot arena??
Curtis's car was a stock block 91 with porting, headers, and a tune. Not sure what else but I know the bottom end was stock.
BTW - the stock pistons have a 250 thousands think top which is great for NOS, it's just the head gasket sealing that's worrysome...
Cheers,
RH
Originally Posted by HADI-ZR1
is it safe to spray 150 hp nitrous in stock Lt-5??
who try it?
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 12-30-2007   #18
RHanselman
RHanselman's Avatar
Hello Bro.
Hadi,
The rear TT car is actually music to the ears and not real loud at all. It's kind of like a B&B without headers on the outside and a Corsa in the cockpit i.e. no resonance. You can drive long distance with the windows up and only hear the turbos sing when you accelerate. To hear the rest of the symphony you have to roll down the windows.
BTW - I just drove it yesterday, it makes you smile from ear to ear...
Cheers,
Ron
Ron Hanselman
Founding Member #80
Old 12-30-2007   #19
HADI-ZR1
Originally Posted by RHanselman
Hadi,
Cheers,
Ron
RON, YOU make me feel like fixing these sexy breast and give it try!
Old 02-04-2008   #20
HADI-ZR1
Hadi,
Cheers,
Ron
now taken this post in thread from CF !
Originally Posted by EPP View Post
The STS kits look like a good deal, here is a list of my opinion of them, and why I don't sell them anymore:
1. STS claims that heat is not required to help spool the turbo, that exhaust velocity does the job.
Major retailers of the STS kits sell the kits with exhaust wrap, to help spool the turbo. We have done this at our shop, and it helps quite a bit. It is obvious that the closer to the engine the turbo is mounted, the more efficient it is going to be.
I copied this from the STS website.
"Doesn't heat create the velocity in the exhaust gasses to spool the turbo?
No, heat doesn't create velocity. Heat creates volume. If you look at any of the physics laws for gasses, you will find that pressure and volume and heat are related. PV=NRT is a popular one, The V isn't for velocity, it is for Volume.
The turbine housing is what creates the velocity. The scrolling design that reduces the volume of the exhaust chamber as it scrolls around causes the gasses to have to increase in velocity and pressure to maintain the same flow rate.
Hotter gasses have more volume, thus requiring a higher A/R which in effect means that it starts at say 3" and scrolls down to approximately 1". Lower temperature gasses are denser and have less volume, so they require a lower A/R housing which would start at the same 3" volume, as the turbine housings use standard flanges, and scroll down to say 3/4".
Now if you were to reverse the housings in application, the conventional turbo would spool up extremely quick, at say around 1500 rpm but would cause too much backpressure at higher rpms because the higher volume of gas couldn't squeeze through the 3/4" hole without requiring a lot of pressure to force it through. On the reverse side, the remote mounted turbo with its cooler denser gasses, wouldn't spool up till say around 4000 rpms but once spooled up would make efficient power because it doesn't require hardly any backpressure to push the lower volume of gas through the larger 1" hole."
So I take it the exhaust wrap should not make a difference?
2. You don't want to run catalytic converters with a rear mount turbo. Years ago a guy brought in a Ferrari to us that had a rear mount turbo. One of the catalytic converters internals came apart, as they sometimes do, and parts of it lodged into the turbo, ruining it. I predict that this will be happening to the STS turbo customers.
3. The oil return line is routed into the passenger side oil cap on the STS kits. This line has a habit of coming loose, and spraying oil into the engine compartment. It happened to us, and I have read where it has happened to other people.
These engines already have enough oil returning down through the heads, they don't need more! This is a bad design, and many people are rerouting the oil return line to the oil pan, where it should be in the first place. The problem with running the line to the pan is now you have to drill or punch a hole into the oil pan to run the oil line, unless you remove the oil pan. We recently removed the oil pan on a customer's car, and welded a bung into the pan for the oil return line.
4. The turbo hangs without brackets supporting it, and will sag over time. We add a bracket when we install these kits, I don't link seeing the turbo dangling there.
5. The air filter is in a bad location, as is susceptible to dust, water, dirt, etc. STS offers a cover that goes over the filter, but we found the cover seriously hinders performance. We proved that on our chassis dyno.
6. On the F Body STS kit, a driver side subframe connector cannot be used. STS claims their plumbing that is routed down the driver side does the job of a subframe connector. We find that humorous, at best!
7. The plumbing underneath the car hangs too low in my opinion, and you don't want a lowered car with an STS kit on it.
8. The silicone couplers that are provided with an STS front mount intercooler are thin, and we had two of them blow apart. The intercooler plumbing that was provided with the front mount intercooler option that we ordered for a customer's car was poorly routed, we ended up using our tubing from our front mount kits that we sell.
9. The oil lines sure have a long way to run, from the front to the rear, and back up front. If a leak developed, it could be a quick way to ruin an engine.
10. It would be relatively easy for someone to slide underneath the rear of an STS equipped car, and steal someones turbo.
11. The boost line running back up to the engine from the turbo has silicone couplers at various points along the way, and can blow apart.
12. Any exhaust leaks will diminish the efficiency of a rear mount turbo.
