Old 09-17-2007   #11
Hammer
Hammer's Avatar
Talking Re: Radiator
Originally Posted by bobbyhi
John - you mentioned to use a "LITTLE" dab of grease. What would happen if you used too much grease?? And what would too much be??
I actually had to wipe some of the grease off as the hoses could be turned with the clamps tightened.
Old 09-17-2007   #12
bobbyhi
bobbyhi's Avatar
Default Re: Radiator
Gotcha....thanks
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 09-17-2007   #13
Hammer
Hammer's Avatar
Gotcha....thanks
You are certainly welcome. Good luck with the install.
Old 09-18-2007   #14
guinnessdood
guinnessdood's Avatar
Bobby...one more thing...those #7 screws...the six on the top radiator shroud way down in front. Use a dremel or something and cut the shroud...and install the clips on the other piece and reverse the direction of the screws..they go in a LOT easier that way. Do you get what I mean?
Uly
Past OWNER 90 ZR-1 #0120 Red/Saddle
UT Plate: EZR1DER
guinnessdood is offline   Reply With Quote
Old 09-18-2007   #15
bobbyhi
bobbyhi's Avatar
Uly, got the hoses on tonight. That is quite a project even with the stuff out of the way. I don't know how you guys got them on without removing a bunch of crap!!! I think I know what you are talking about with the #7 screws. I am going to work on putting on the shroud tomorrow evening. I'll let you know how that goes . Thanks for the tip about the screws.........
Bob Anderson
Founding Member #19
Old 09-18-2007   #16
Jeffvette
It's fairly simple. The most you should have to remove is the belt tensioner. I have had to remove the oil cooler lines on one car as whomever set the clamps did not pay attention to the orientation.
But yes, it is tight. A little silicone grease goes a long way.
Old 09-18-2007   #17
bobbyhi
bobbyhi's Avatar
You are sooooo right about the silicone grease. Really made the hoses go on pretty easily. Just finished installing the shroud. All I have left are the #7 screws. It was too late to use the dremel and reverse the screws but tomorrow evening I will attempt to get at least 2 on per side. That top one might not be installed. I don't see any problems occurring if it isn't there!!! Should be able to put the fluid back in also tomorrow. This was a pretty big project for a "shade tree mechanic". Thanks to all you guys for your help and support.....probably wouldn't have done it if it weren't for your guys
Bob Anderson
Founding Member #19
Old 09-19-2007   #18
bobbyhi
bobbyhi's Avatar
Final report - IT IS FINISHED=D> The beast is back on the road again
Bob Anderson
Founding Member #19
Old 09-19-2007   #19
Hammer
Hammer's Avatar
Nice. It should run cooler now too. Congrats Bob.
I have a header install coming up. Winter project though. I am talking with Jeff tonight about P&P the Inj housings and Plenum as well as some powdercoating. Red/Black car, I think I am staying with the silver. Any other combos look good in this car. Red maybe?
Old 09-19-2007   #20
jonszr1
jonszr1's Avatar
on those little screws . i know some might find it mickey mouse but i used small tie wraps which after 7 months are still holding
