#11 |
hi all, harold again, we checked all systems as to the tips you all sent in, such as secondary port vacuum system, and it holds 12hg. going under the plenum and also back to the pump.fuel pumps are new as are o2 sensors.car still shows a code 61, and wont run over 3000 rpm.if engine passes the vacuum pump test ,can i assume everything is ok under the plenum,or do i need to take the plenum off and check furthur?also, is there a way to check the ecu. i really appreaciate your input. thanks again Harold
#12 |
if its holding vaccume i believe you should be ok under there ,i think the onlt exception would would be the port throttle selinoid? but would have to defer to jeff on that to know for sure . have you tried disconnedting the battery for a couple of minutes then rahooking it uop to reset any codes you may have. wish i could help more . oh havve you cked to see if you vaccume pump comes when you turn the key to on ? .
#13 |
So you have a tech 1?
#14 |
to jeffvette, what thew heck is a tech 1? harold
#15 |
Tech 1 is the tool you need to troubleshoot the system.
#16 | |
![]() Join Date: Jul 2007
http://www.rotomation.com/a032.htm Should be fairly simple to tie into the existing circuit for the solinoid to run this thing. I've only done wayyy preliminary thinking about it though. KT |
#17 | |
![]() Join Date: Dec 2004
Not having a Tech1A was why I was mad when I finally concluded that my ECM was the root of my code 61....without it and it's testing software I couldn't do all the diagnostics...I had to make assumptions and follow either a "yes" or "no" answer to the end of the diagnostic tree to find I had "guessed" wrong. Had I just swapped out the ECM before I pulled the plenum I would have seen that the ECM was at fault from the get go. ![]() ![]() Tom If I had a spare ECM I would lend it to ya to test...but it's now in my car! ![]()
#18 |
hi all,Harold again,still suffering from same problem, wont rev over 3000rpm and ses lite still on. we cleared the ecm, and ses lite went out and engine would rev freely above 3000 and beyond. this lasted about a minute,and the ses lite came back on and engine wont rev past 3000 again.any ideas?thanks,harold
#19 |
It keeps coming back because you have not corrected the issue of lack of vacuum.
#20 |
hi guys, can anyone tell me where i can buy a tech 1 tool? thanks, Harold
